Question about Protron PLTV-32 Television
Protron PLTV 32 - audio output jacks not working correctly
Have red and white output jacks on the PLTV 32 for audio output to stereo receiver - the white jack works but the red one does not. Tried different cables and different audio outputs on the receiver to make sure. Is it worth the time and hassle to take this TV to a local source to try to fix the problem?
  • Crash Crook Feb 04, 2009
    how do you see if it is on mono
  • Anonymous Mar 12, 2014
    are there audio output jacks
  • 362 Answers
Hi reb21, From the Audio menu check and make sure your audio output is not set to Mono, anyother setting should produce a an output signal on both wires. Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
How do I connect my Dell laptop to the tv speakers ? Not for video - only for sound . Thanks, TJ
You will need an 1/8" TRS Stereo Male to Stereo RCA(Red and White) Male adapter. Plug the 1/8" TRS into your Laptop Speaker Out, or Headphone Out, and plug the RCA Stereo cable into your TV Input.
Mar 07, 2011 | Protron PLTV-32 Television
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
Im trying to find an audio output for my tv or a headphone jack but with so many things on the tv i cant find it.. help
There should be two RCA jacks on the back for left and right audio outputs, white and red respectively, if it has stereo out. Connect these outputs to a stereo receiver or amplifier into an auxiliary port or TV audio input via a red and white RCA cable.
Nov 10, 2010 | Televison & Video
Tv has no sound
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 20, 2010 | Protron PLTV-32 Television
A week ago I E-mailed you this queston. I also agreed to pay $12.99 to "Fix ya" for an answer. I'm not satisfied with the answer. My question was that I have a Protron PLTY-3250 flat screen TV. I need...
The response to your question is in two parts. There should be a couple of RCA jacks on the rear or side of the set labeled "output". These need to be connected to the input of the wireless headset transmitter. The second thig is to determine where the volume is to be controlled. The output from the set can be either Fixed or Variable. This means that teh volume can be controlled by the volume up/down at the set or not. Fixed mode is for connecting to a receiver where the volume is controlled by the receiver and changing the volume at the set will have no effect. Using the variable output mode will allow you to control the level of audio entering the transmitter and thus the volume. This assumes that the headphones do not have a volume control on them.
Setting the output to be either Fixed or Variable is controlled by the audio menu of the set. Please note that in variable mode, any internal speakers would need to be disabled as well.
Hope this helps,
Dan
Jan 07, 2010 | Protron PLTV-32 Television
Conecting to souround sound
find the audio output jacks. Should be one red and one white, that say output by it. You can get the RCA Audio Jacks that plug in to the tv audio output jacks to your receiver or stereo INPUT jacks.
Aug 05, 2009 | Televison & Video
Sound/ no picture
Can't really help you with getting sound out of the tv speakers, but you may be able to use the audio outputs from the TV to a receiver as a work-around.
Nov 15, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
183 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
