My computer start but no display !!!
My pc specs is : the computer is a fujitsu siemens computer scaleo. motherboard asus m2r-fvm. Processor amd athlon x64 4800+ 2,5 ghz. Ram 4x1gb. Graphic card nvidia gtx 550 ti gddr5. Power supply is 450 w I have changed power supply i had a 350 w before i upgraded to 450 w. I had an nvidia gt 220 before. But now i have gtx 550 ti. I had this problem some days ago. This happened to me the computer start but no display. Then i take off 3 off my ram and let 1 gb ram on my computer. Then the computer started. then i shutdown my computer and putted 4 gb ram. the computer started and i runned windows startup repair and it worked. But when i shutdown or restart the computer, the problem come back. But i tried to do the same as i did take out 3 rAm sticks. But it dont worked. Please reply :)
  • 2,878 Answers
Test the RAM as you did, only using stick at time and one slot a time. 4 slots by 4 DIMMs equals 16 different possible combinations to try.
You could also use memtest86 (Not for the novice) It is part of a free boot utility CD.http://www.hirensbootcd.org/download/ Download. Burn and use.
Posted on Dec 11, 2012
  • 244 Answers
SOURCE: Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Posted on Nov 24, 2007
tom19511
  • 1601 Answers
SOURCE: Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Posted on Dec 12, 2007
nyilasrobert
  • 627 Answers
SOURCE: Computer won't load past Boot and now doesn't display anything!
the memory stick going in one way into the module. If you can't close the clips try to rotate it 180 degrees.
when windows starts hit F8 key and select disable automatic start on system failure.
This will bring you a blue screen with the specified error
also you can boot from windows xp cd and at first screen select repair, this will put you in recovery console
in recovery console you can scan your hardrive for errors like this:
chkdsk c: /p /r
Posted on Jul 17, 2009
SOURCE: i'm using: 1. Asus motherboard
Any sound of mother board? Just tell me clearly. Or better you check your processor, means remove & add again.
Posted on Aug 12, 2010
bronk50
  • 27725 Answers
SOURCE: Can i fit Nvidia Geforce
Intel Desktop Board DG41RQ Essential Series - motherboard - micro ATX - LGA775 Socket - iG41
Read more: http://reviews.cnet.com/motherboards/intel-desktop-board-dg41rq/4505-3049_7-33518531.html#ixzz1LHb2VOLo
hope this helps
Posted on May 02, 2011
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Succes.
Jan 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
After reformatting my ASUS P5VDC-MX lost sound.
That would be expected, because as mentioned above, its a motherboard manufactured for Fujitsu-Siemens, not maintained or supported by ASUS !!
The drivers can be obtainedfrom the chip vendors whose products are used on the board. ASUSdoesn't make Intel or Realtek chips.
Intel 845GE/ICH4 =
http://downloadcenter.intel.com/default.aspx
Realtek ALC65x AC97 Audio =
http://www.realtek.com.tw/downloads/
Realtek RTL8101L LAN =
Windows Update will have fairly recent drivers for every device on this board. Additionally, FSC maintained an all-encompassing driver update package for Scaleo models active between 2004 ~ 2006:
http://www3.fujitsu-siemens.com/services/homepc/scaleo.zip (76MB)
I sincerely hope that one of the above will work................sodeep
Oct 26, 2009 | ASUS P5VDC-MX Motherboard
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
POWER TO MOTHERBOARD NO BEEPS AND WON'T BOOT NO SIGNAL ON SCREEN
Open the PC and try reseating the memory and processor before condemning the motherboard. Also, as an FSC computer, check the processor is not one of the batch which had the incorrect heat sink fitted - if it is, you will be entitled to a free processor replacement form the FSC helpdesk.
Oct 27, 2008 | Biostar K8M800-M7A Motherboard
Scaleo 600
Are you still having the same problem?
On a computer an amber light is usually a "busy" light from when the hard drive is being accessed.
Nov 03, 2007 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Computers & Internet Logo
David Payne
David Payne
