Question about Brother IntelliFax-2820 Laser Fax
Fax machine broken need to forward to different fax
It keeps saying close back cover and will not receive faxes. Need to forward to another Brother machine immediately
    Champion:
  • 320 Answers
HELLO! OPEN THE BACK DOOR AND CHECK IF THE SENSOR FELL OUT, IF YES PLEASE SNAP IT BACK IN WITH OUT BREAKING IT
Posted on Jan 15, 2009
Says to replace drum soon, i've bought two, and still can't make copies or receive faxes]
Perform the manual drum counter reset. Open the front door cover & keep open. Then press clear. It should say replace drum, press 1 for yes it should then say accepted. Close cover & off you go.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Screen reads "back cover open" and it is not open. it will not allow us to receive faxes....???
there is possibly a switch actuator that has broken on the cover. check cover for any missing or broken pins on the cover. jaime
Jul 08, 2010 | Brother IntelliFax-2820 Laser Fax
Keep receiving duplicate faxes
Some Brother fax machines are programmed incorrectly so they do not acknowledge receiving the last page of a document. The sender doesn't know you got it, and will resend.
It's harsh advice, but the only solution is to buy a different brand.
May 07, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax display says, close back cover even with back cover closed.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
I want to receive my copies out the front not the back of the fax/copy machine.
You will need to close the back cover. The reason its comming out the back because it has been left open.
Mar 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
Brother MFC-7220 says close back cover but it's already closed
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Drum problems
After reinstall the new drum unit, keeping the front cover open.
Press Clear/Back.
Press 1 and when the LCD shows
Accepted, and close the front
cover.
Jul 17, 2008 | Brother MFC-8220 Fax
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
141 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
