Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Where is oil sensor on honda gx160 5.5 - Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
    New Friend:
    Problem Solver:
  • 11 Answers
The low oil sensor is on the front of the block the wires are attached to ur start stop switch. It has two wires yellow and black on most models. the sensor itself is internal
Posted on Dec 11, 2012
2001 Honda Varadero 125 oil light warning@
Hi, Anonymous and the usual suspects are:
1. Insufficient oil level or no oil in engine or tank.
2. Air in oil system that needs to be bled.
3. Blockage in the oil tank or line.
4. Oil pump failure.
5. Faulty oil pressure sending unit.
6. Grounded oil pressure light circuit.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda xl 125 v1 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/227 Honda XL125V Veradero
Honda XL125V Varadero
Mar 29, 2013 | 2001 Honda XL 125 V Varadero
Honda civic 2008 where is oil temperature sensor located?
There is no oil temp sensor that I know of, there is an oil pressure switch right above the oil filter. Let me know if that helps.
Eddie,
www.simple-car-answers.com
Mar 05, 2013 | Honda Civic Cars & Trucks
I have changed the oil in my Honda accord and the oil light flashes for a few minutes stays on and then goes back off.
check all of your sensor wires also make sure that it has enough oil and it may just be a bad sensor but first thing i would do is check to make it has enough oil
Jan 16, 2011 | 1997 Honda Accord
Honda 3000 eu no spark replace ing coil still no spark
Is there enough oil in the crankcase? Many generator ignition problems come from the oil level sensor. Either not enough oil or the sensor being bad.
Jul 21, 2010 | Honda 3000 Watt Portable Generator
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
91 Honda civic is leaking oil from a sensor located on the head is not the oil sensor the location of this sensor is on the left side of the head facing the fire wall
If the engine has an overhead cam it could be the cam position sensor.If the threads are leaking remove it wrap teflon tape on the threads and re-install it. If oil is leaking threw the sensor replace it.
Mar 25, 2010 | 1993 Honda Accord
Honda accord 2007 service code A23 what does this mean?
Code 23 is the knock sensor,but this does not mean the sensor is faulty,could be picking up a knocking in your engine.Check oil level and oil pressure.Check wiring to the ecu from the sensor.
Mar 03, 2010 | 2007 Honda Accord Sedan
Check engine light after every oil change 2005 Honda
This happens because the oil filter needs to be free of air. When the oil pressure sensor drops below a certain value it shuts off the injectors because the PCM. This is a good feature because if you run out of oil for any reason it should stop the engine before damage occurs.
Apr 22, 2009 | 2005 Honda Accord
Honda accord oil light
First I would change the sensor. It is cheap and easy to change.
Mar 06, 2009 | 1993 Honda Accord
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
226 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
