Hdmi2 is not working
When I try to connect any source there is no signal on this chnnnel
  • 8,617 Answers
The HDMI port has failed very common problem if another drops out soon you will no doubt need to replace the main board as usually they fail one after another if its a main board issue, If just the one fails then its most likely just the HDMI port itself which has failed and replacing just the port should repair the issue. You can get replacement HDMI ports and also complete main boards from www.tvcircuitboards.com
Posted on Dec 11, 2012
My seiki tv got turned on to hdmi1 mode. How do I turn it off. I don't have an hd tv. The screen is blue and it says hdmi1 at the top and no signal.
you need to press source on the remote. That will let you choose what signal to use. TV, hdmi1, hdmi2, and more options will show
Oct 23, 2016 | Seiki Televison & Video
How do I fix hisense TV on standby
Televisions go into standby mode when there is not an input source. First try cycling through the inputs i.e. HDMI 1/HDMI2/CABLE/VGA/RCA etc. next try changing the cable you are using. It may be bad. Outside of that, either the input port has gone bad on the board or the source is not sending a signal, either way this would be something handled by a professional repair technician
May 04, 2016 | Hisense Televison & Video
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Why can't my TV find a digital signal when connected to my digital ready aerial? Tuning for digital stations finds none. Does this TV require a set top box? If not how can I make it find and play n
hey, when connect any aerial in the back of the TV make sure you have a look for the name of the connection you use ( Skart,ext1,ext2,usb,hdmi1, hdmi2 etc.) so you can do a search on that extension. if you connect something on Hdmi1 and search on hdmi2 you won't find anything. you have to search on Hdmi1. PS: good luck.
Jan 24, 2015 | Televison & Video
On my tv it has 3 hdmi connections and only the hdmi 1 is working after plugging the device in it you can change channel to the other 2 and it shows what is on hdmi 1 and the others will not recieve a...
check your avsource setup, it should be hdmi1, hdmi2 and hdmi3 selection on your audio video source programm.. othe wise it will auto detect signal.
May 30, 2011 | Televison & Video
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
Apr 24, 2010 | LG 50PC5DC 50 in. Plasma HDTV
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
