Question about Garden
Idle speed varies
Engine speed cycles up and down about once per second
  • 2,239 Answers
This is dirt in the carb, remove the float bowl and main jet, blow out with air and re try
Posted on Dec 15, 2012
I got a Audi A4. When idle, it surging. Why
Throttle Body Cleaning on vehicles without electronic throttle control (most 2003 and down)
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
Jul 11, 2017 | Audi A4 Cars & Trucks
Honda eb5000 generator starts fine seems to run good but idle control does not work . will not rev up at all.i can turn carb idle screw in to bring revs up it makes power out of the generator but idle
Like a lot of stationary engines a generator engine is governed, or at least should be governed.
That is to say, when the engine is started it should be running at a predetermined speed which is not an idle speed but the speed the engine works most efficiently and that typically would be in the region of perhaps 1800 to 2500 rpm. In the case of an alternating current (ac) generator the speed will be determined by the alternator and the requirement of the frequency of the ac output to be around 50 to 60 cycles per second.
It is the function of the governer to maintain that preset speed within fairly close limits so when an appliance is connected to the generator and switched on the load increases and if it were not for the governer the engine would slow down which would be unacceptable. The governer therefore opens the throttle and restores the speed to the preset value. When the extra load is removed the engine will speed up momentarily and then restabilise at the right speed.
The governer is somethimes an engine driven set of bob-weights hidden inside the crankcase and sometimes nothing more complicated than a flap moving against a spring in the blast of cooling air from the fan. In all cases the governer is connected to the carburettor, typically by an adjustable link that includes a spring.
From your description it would seem the governer of your generator engine is jammed, broken, seriously maladjusted or simply no longer connected.
I hope this helps.
Feb 04, 2015 | Honda Eb5000 Eb7000 5000 7000 Generator...
Truck dies when idling
HI
first I would like to tell you, do this procedure only if the 5th digit of your VIN is C or K.
Description
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
Conditions for Running the Throttle Learn Procedure
• DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts.
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code
(DTC) List - Vehicle.
1. Start and idle the engine in PARK for 3 minutes.
2. With a scan tool, monitor desired and actual RPM.
3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4. Ignition OFF for 60 seconds.
5. Start and idle the engine in PARK for 3 minutes.
6. After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
* If the engine idle speed has not been learned the vehicle will need to be driven at
speeds above 70 km/h (44 mph) with several decelerations and extended idles.
7. After the drive cycle, the engine should be idling normally.
* If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds
and repeat step 6.
8. Once the engine speed has returned to normal, clear DTCs.
Good Luck
Mar 04, 2014 | 1995 GMC Sierra
My 05 chevy malibu is not excelerating or shifting properly...
I would test both the tps and map sensors.
map sensor is here:
Testing
Check the Manifold Absolute Pressure (MAP) sensor circuit as follows:
Ignition OFF, disconnect the MAP harness connector at the MAP sensor.Ignition OFF, test for less than 5 ohms of resistance between the low reference circuit terminal 2 and ground.If greater than the specified range, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the ECM.Ignition ON, test for 4.8-5.2 volts between the 5-volt reference circuit terminal 1 and ground.If less than the specified range, test the 5-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.If greater than the specified range, test the 5-volt reference circuit for a short to voltage. If the circuit tests normal, replace the ECM.Verify the scan tool MAP Sensor parameter is less than 1 kPa.If greater than the specified range, test the signal circuit terminal 3 for a short to voltage. If the circuit tests normal, replace the ECM.Install a 3A fused jumper wire between the signal circuit terminal 3 and the 5-volt reference circuit terminal 1. Verify the scan tool MAP Sensor parameter is greater than 126 kPa.If less than the specified range, test the signal circuit terminal 3 for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.If all circuits test normal, test or replace the MAP sensor.
Check the Throttle Position (TP) sensor circuits as follows:
Ignition OFF, disconnect the harness connector at the throttle body.Ignition OFF for 90 seconds, test for less than 5 ohms of resistance between the low reference circuit terminal C and ground.If greater than 5 ohms, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the ECM. Ignition ON, test for 4.8-5.2 volts between 5-volt reference circuit terminal E and ground.If less than 4.8 volts, test 5-volt reference circuit for a short to ground or an open / high resistance. If the circuit tests normal, replace the ECM.If greater than 5.2 volts, test the 5-volt reference circuit for a short to voltage. If the circuit tests normal, replace the ECM. Verify the scan tool TP sensor 1 voltage is less than 0.1 volt.If greater than 0.1 volt, test the signal circuit terminal D for a short to voltage. If the circuit tests normal, replace the ECM. Verify the scan tool TP sensor 2 voltage is greater than 4.8 volts.If less than 4.8 volts, test the signal circuit for a short to ground. If the circuit tests normal, replace the ECM. Install a 3A fused jumper wire between the signal circuit terminal D and the 5-volt reference circuit terminal E of the TP sensor 1. Verify the TP sensor 1 voltage is greater than 4.8 volts.If less than 4.8 volts, test the TP sensor 1 signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM. Install a 3A fused jumper wire between the signal circuit terminal F and the low reference circuit terminal C of the TP sensor 2. Verify that the TP sensor 2 voltage is less than 0.1 voltIf greater than 1.0 volt, test the TP sensor 2 signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the ECM. Ignition OFF for 90 seconds, disconnect the harness connector at the ECM.Test for less than 5 ohms of resistance on all TP sensor circuits between the following terminals:ECM C2 signal circuit terminal 65 to TP terminal DECM C2 signal circuit terminal 63 to TP terminal FECM C2 5-volt reference circuit terminal 3 to terminal E If greater than 5 ohms, repair the affected circuit for open/high resistance.Test for infinite resistance between TP sensor 1 signal circuit terminal D and TP sensor signal circuit terminal F.If less than infinite resistance, repair the short between TP sensor 1 signal circuit and TP sensor 2 signal circuit. If all circuits test normal, replace the throttle body.
Fig. Throttle Actuator Control electrical connector
Throttle Body Relearn Procedure
NOTE
Start and idle the engine in PARK for 3 minutes.With a scan tool, monitor desired and actual RPM.The ECM will start to learn the new idle cells and Desired RPM should start to decrease.Ignition OFF for 60 seconds.Start and idle the engine in PARK for 3 minutes.After the 3 minute run time the engine should be idling normal.
NOTE
If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.
If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 6.Once the engine speed has returned to normal, clear DTCs.
Jul 29, 2017 | 2005 Chevrolet Malibu
Drive cycle
Here is the OBD2 emission system drive cycle test procedure.
Engine coolant temp must be below 70c (158f) before starting the engine for either the first or second trip
The fuel level should be less than 1/2 full
First trip:
Start engine, idle for at least 1.5 minutes
Drive 3 minutes, hold b/f schdl: 1.5-2.0 msec, selector lever "3rd" eng rpm 1,800-2,000 A/C switch:ON Hold the recommended b/f schdl range. Allow road speed to vary as necessary.
Drive at 55-65 mph for 1.5 min b/f schdl 2.0-3.2 msec, selector lever "5th" Engine rpm 2,200-3,000
IGN "off" for at least 10 seconds (not more than 5 min)
Dive at 50-60 mph for 3 minutes Selector lever "4th" keep engine speed above 3,000 rpm Allow speed to vary if necessary. Do not decelerate for more than 3 consecutive seconds. A/C switch ON.
Drive at a steady state cruise of 53-58mhp b/f schdl more than 1.8 msec selector lever "5th" eng rpm 2,400-2,600
Downshift to "4th" and decel more than 5 seconds without breaking, then idle for 1 minute.
Drive two minutes b/f schdl less than 2.0 msec Accelerate to 41 mph, decelerate to 34 mph, accelerate to 41mph. Do not completely release the accelerator. A/C switch off.
Idle 1 minute in park or neutral
Drive two minutes Steady state cruise at 31-44 mph. Selector lever "4th" A/C switch OFF. Hold the accelerator pedal as steady as possible. Allow speed to change if necessary.
End of first trip. Turn the key off the begin the second trip.
Second trip:
IGN "off" add four gallons of fuel
Drive two minutes Steady state cruise at 31-44 mph. Selector lever "4th" A/C switch OFF. Hold the accelerator pedal as steady as possible. Allow speed to change if necessary. I especially like the part where they want you to add four gallons of fuel. Not three gallons, not five gallons, four gallons. Gotta love those Nissan engineers. ...and of course they state that if the trace is not followed exactly (i.e. you botch the acceleration/deceleration) you have to start all over again from scratch
Feb 09, 2012 | 1996 Nissan Pickup
Not Ready for Smog test
it is not how many miles but the type of driving.
here is a OBD2 drive cycle test.
Generic OBD II "Drive Cycle" Most OBD II ("On-Board Diagnostics II") diagnostic monitors will run at some time during normal operation of the vehicle.
However, to satisy all of the different Trip enable criteria and run all of the OBD II diagnostic monitors, the vehicle must be driven under a variety of conditions. The following drive cycle will (theoretically) allow all monitors to run on (??) vehicle. (Note: Drive cycle specifics vary by vehicle!)
  1. Ensure that the fuel tank is between 1/4 and 3/4 full.
  2. Start cold (below 86°F /30°C) and warm up until engine coolant temperature is at least 160° F (typically requires at least one minute; up to 3 minutes).
  3. Accelerate to 40-55 MPH at 25% throttle and maintain speed for five minutes.
  4. Decelerate without using the brake (coast down) to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
  5. Restart and accelerate to 40-55 MPH at 25% throttle and maintain speed for two minutes.
  6. Decelerate with using the brake [or the clutch!] by coasting down to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute.
Jun 04, 2010 | 2001 Kia Sephia
2.7 crd.grand cherokee 2002. Varying idling speed,dimmng lights
well it could be the idle control valve or vacuum leak check all vacuum lines for cracks and listen for air sound you may need to check PVC valve
Feb 08, 2010 | 2002 Jeep Grand Cherokee
How to I set idle speed?
Before performing any on-vehicle adjustments to fuel or ignition systems, ensure engine mechanical condition is okay. CAUTION: When battery is disconnected, vehicle computer and memory systems may lose memory data. Drive ability problems may exist until computer systems have completed a relearn cycle.
IDLE SPEED & MIXTURE
NOTE: Idle mixture is controlled by Powertrain Control Module (PCM). Adjustment is not possible. After replacement of Idle Air Control (IAC) valve, system must be cycled as identified for PCM to properly control idle speed. If idle speed is not okay after cycling system, problem is usually caused by a dirty throttle plate or vacuum leaks. Ensure all vacuum components are functioning properly.
IDLE SPEED (4-CYLINDER)
Turn ignition on with engine off for 10 seconds. Turn ignition off for 10 seconds. Start engine and idle for 30 seconds. Slowly vary engine speed between idle and 3500 RPM 5 times. Return engine to idle. PCM will now properly control idle speed. 2.2L (Cavalier & Sunfire) & 2.4L (Alero, Cavalier, Grand Am & Sunfire)  Good luck and hope this helps. If it still has the high idle problem, your going to have to buy a can  if not two cans ot THROTTLE BODY CLEANER NOT CARBURATOR CLEANER. Just follow the instruction on the can and try to get the Idle Air Control Valve cleaned also which is on the sdie of the throttle body so go to town when cleaning the throttle body and then do the Idle speed relearn again. The other thing to is since your doing house cleaning, buy a MAF sensor cleaner and spray down your MAF sensor and IAT sensor also, this will help with your fuell consumption.
Good luck and keep me posted, be glad to help.
Jul 04, 2009 | Oldsmobile Alero Cars & Trucks
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
