Question about Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3 inch ) 2x , Rewritable DVD Camcorder Media (SDVDRW)
My handycam rewritable cd shown in blank in computer
  • Sony Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Posted on Jan 14, 2013
What type of blank disk does the handycam use -R or -RW ?
hi,
you can use both...
the difference between R and RW is Recordable (only once) and Re Writable (erasable an rewritable)
May 15, 2014 | Sony Handycam DCR-DVD108 DVD Camcorder
LG super Multi DVD Rewriter GE20 The drive itself works fine on another computer, as it did on mine, but now when I put a blank DVD in I can not burn it. The list of drives on my computer the drive names...
Are you using the same blank cd / dvds are before for burning?
You might want to check LG's support page to make sure you're using the latest drive firmware version.
Here's a link to their page.
There are two GE20 models so make sure you choose the one you own.
Let me know what happens after the above.
Mar 23, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
I have Dell computer and the CD burner is not working
how do you burn a audio cd from a dell computer cd drive d
Apr 04, 2009 | Computers & Internet
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
KDS Laptop CD ''D'' drive won't recognize blank CD WIN ME
On the face of the CD drive drawer, does it say "CD" or "CD-RW" (or "CD-RW/DVD")? If "RW" or "ReWritable" isn't present, you can't write to blank CDs. You can only read prerecorded ones.
Mar 01, 2009 | KDS Valiant 6380iPTD-01 Notebook
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Problem with dvd rewriter
You're probably using the wrong format dics.
Feb 14, 2008 | Computers & Internet
Not able to write to CD-R directly
Problem: with Sony Handycam.......... DCR-HC26
After installing the disc that came with the camera and the wizard, and some other programs, Picas, my computer does not find the camera . Says I need a CDR driver also. Can I find one to download free someplace?
Thanks.
Jack
Sep 03, 2006 | Sony Handycam DCR-TRV265E Digital...
Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3 inch ) 2x , Rewritable DVD Camcorder Media (SDVDRW) Logo
93 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
