Question about McCulloch 1975 Mini Mac 30 Chain Saw Sales Brochure W/ Specs
Mcculloch Mini Mac 30 Oiler does not work. cant figure out if it is the Oiler or the manual pump to feed the oiler
Took appart the Oiler. It seems to work a bit by manipulating the piston manually.. the Manual Oil pump from the oil tank... does not seem to push any oil out..
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
puertobori
  • 7733 Answers
SOURCE: The manual oiler on my mac 110 does not work. The
Give a try at Lawn and Garden Manuals.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Mar 17, 2011
I have a McCulloch CS38EM Why is the auto oiler not producing oil to chain. The port seems to be clear.
There is a spiral ring that drives the oiler on the crankshaft. Sometimes that slips and no longer turns the oiler. You can move it back and put a few drops of thread locker on the shaft before you place the spiral in place.
Oct 28, 2016 | McCulloch Garden
Cant get the chain oiler to pump oil. Can hear it pumping
If it has oil and is not pumping it, then it is probably blocked by a wood chip that fell in to the oil when you opened the cap.
You need to blow it out with air, backwards.
Aug 26, 2010 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Oil System Plugged:
Lou
Apr 30, 2010 | McCulloch Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
Oiler does not work on Mac 3200 chain saw
I cannot find any 3200 series IPLs. Individual models can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Lou
Oct 20, 2009 | McCulloch Garden
Automatic oiler does not work , mcculloch em300s (electric), automatic oiler must be clogged? is there a pickup tube that can be blown out? need parts diagram to figure out if there is a pump inside.
I wasn't able to find your IPL with what you provided. Somewhere (probably bottom) should be a black and yellow tag with the serial and model numbers. The model number on that tag is the key to your IPL. If you get that far and hit a dead end with parts repost with the correct model number and your best guess at what is defective. I've had great luck finding Mac parts for my saws.
McCulloch IPLs
HTH
Lou
Oct 18, 2009 | McCulloch Garden
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Jun 18, 2009 | Standard Oregon Chainsaw Chain For...
McCulloch 1975 Mini Mac 30 Chain Saw Sales Brochure W/ Specs Logo
128 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
