check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
The start of the spin cycle is dependent on the pump pumpin out water and the later level switch sensing that the water level is low enough. The water level switch has (usually) a clear tube connected to it and is found in the control panel. You will want to check continuity at different times. First you will fill the tub to the highest water level. Then unplug the machine. By screwing in the screw on the water level switch. Scew it all the way in. then you will check continutity. there should be no cont. between green and brown. and there should be cont between green and black or yellowblack. Do this continuity test with the wires off the switch. Once this test is complete, reattach the wires and plug in the machine and set the timer on spin or drain. When the tub is pumped dry, stop the spin cycle and unplug the washer and do the continuity test again. This time you should have continutiy from green to brown. and no continuity from green to black or yellowblack. Now when i mention the colors that means the placement where those wires were. Make note before you remove them so that you can get them back to place. If you do not get these readings, the water level switch is bad, or there is a leak in the air pressure tube leading to it. At that point I would replace the entire switch and tube. I wish you the best of luck.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
