Question about Sewing Machines
Material is sucked into bobbin area with main motor block massage
Needle thread seems to be catching in the racing unit of the bobbin area
  • Sewing Machines Master
  • 1,564 Answers
That sounds like an operator error. Get into the habit of grasping both threads and holding them as you start the seam.
Posted on Dec 12, 2012
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
How do i fix the top thread just tangling, looping on the shutter race?
1. Make sure that you are using the right bobbin case. (LX3125) 2. Adjust the tension of the bobbin case. (I've sent a guide for this) Your's is considered the older style.
3. Make sure the bobbin that is used is the right one. If it is too long or too wide it will cause problems.
4. When you insert the bobbin case make sure the lock handle goes down flat with the bobbin case. Also, feel the bobbin case for rough snags.
5. Replace the needle. Insert it the new one in the right direction.
6. Thread the machine (while pressure foot up) according to the directions. While threading give small tugs to check for snags.
7. Place the tension on four. It is ok to feel by hand if this is excess tension.
8. While turning the hand wheel towards you the bobbin thread should rise above the throat plate.
9. This should be ok now. Try it on some old rags. Don't forget to set that bobbin case.
Jun 08, 2015 | Brother LX3125 Sewing Machine
Bobbin thread bunching and top thread breaking
After double checking your threading path, changing your needle, ensuring you have good quality thread, and cleaning under the needle plate and in the bobbin race area, if none of that helps your problem, check the hook that goes around the bobbin for a burr that could be catching and not releasing the upper thread on its trip around the bobbin. Remove the hook from the race if you can, and run your fingernail from the base to the tip of the hook on all sides, watching for it to catch on something. If it does not, let me know and I'll dig deeper. If it does, use a very fine emery board or cloth and just barely touch it to the hook, stroking from the base to the tip very very gently. That should knock the burr off, reassemble and test.
Apr 28, 2012 | Singer Sewing Machines
The cotton keeps getting caught up in the bobbin area
try these suggestions
1. change needle--flat side to the back of the machine
2. needle must the correct one for the fabric
3. check the bobbin to make sure it's not damaged or warped
4. check the bobbin case( the thing that holds the bobbin) to see if there
are any burrs on it or see if it's damaged is some way
make sure the bobbin case fit's snuggly into the hookrace
5.it's also possible that the machine could be out of time
Apr 18, 2012 | Sewing Machines
Bobbin case making noises and bobbin thread keeps breaking the material also pukkers up underneath
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Mar 07, 2011 | Elna Xplore 8600 Computerized Sewing...
The bobbin keeps jamming up and is not catching
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 05, 2010 | Husqvarna Freesia 415
The needle doesn't catch the thread in the bobbin
Are you certain the needle is not bent and that it is in the right way around? Which model is it?(I used to sell them)
Jun 21, 2009 | New Home Sewing Machines
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Good luck.
May 19, 2009 | Husqvarna Freesia 415
Hi I am pretty sure that the bobbin and the thread are in correctly but when I put the material in the needle just put holes in the material. what am I doing wrong?
you may have adjusted the upper tension and made it so tight that the thread just pulls out of the needle and needle makes holes in fabric. you might want to check the feed of the bobbin, it will not allow the machine to sew if it is not able to be picked up by the needle. the bobbin thread is usually (when held in your hand) with the thread coming counter clock wise. and then it will lay in the bobbin holder and the end of the thread will come back to about the slide catch thing and be held there until the needle thread catches it (leave the cover off the bobbin area until you watch and see what happens then. Try adjusting the bobbing tension too hope you understand what I mean here.
Mar 07, 2009 | Singer 7444 Mechanical Sewing Machine
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Not catching stitches / bobbin correctly
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Oct 05, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
