Question about Frigidaire ATF6000ES Front Load Washer
Washer Feels like there are gallons of water in the bottom
My washer smells bad when I run a cycle to wash my close and I feel like they are not getting clean
  • Official Brand Answer
  • 4,342 Answers
Hello Holly Davis -
Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately. However, regarding the odor my advice to you is first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Posted on Dec 14, 2012
eandlfan
  • 9 Answers
SOURCE: washer repair
The transmission might have locked up causing the motor to overheat.
Posted on Dec 23, 2007
aborcass
  • 2651 Answers
SOURCE: Washer won't spin or drain water
you checke dthe drain??? how??? i would assume that you have something stuck within your drain pump assy( bra underwire-- money--- toothpick--nail/screw) VERY common issue, youll need to remove the front cover and remove the hose leading to the pump to look inside. DISCONNECT POWER-- PUMP IS ALWAYS LIVE!!!!!!!!!!!, oh yea and youl need a bag to collect the water when you disconnect the hose, YOURE GONNA GET WET!!
Posted on Oct 19, 2008
localwonder
  • 6784 Answers
SOURCE: Won't spin after wash cycle or rinse cycle
CHECK THE FOLLOWING---
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on May 31, 2009
  • 3741 Answers
SOURCE: Washer will not spin for
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 11, 2009
SOURCE: cleaned coin trap and now nothing is working.
just fixed mine took off 3 screws on bottom of washer removed panel unscrew round access in front of pump & found clogged debris also took all hose,s off & flushed out this cured the problem i think the clogging was cuased by using wrongt detergent
Posted on Jul 20, 2009
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
5 month old Whirlpool Cabrio washer has moldy smell. Tub seems to empty well. Any ideas?
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
May 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
The rubber round my washing machine door is black and smells
common problem with that style machine. Try running a cup of vinegar thru te wash cycle. The acid from the vinegar will break it down. It may take more than one cycle if its really bad. Once the smell is gone leave the door slightly ajar to prevent it from happenig again.
Feb 28, 2009 | CDA CI392 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
47 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
