Question about Hitachi CP-X300 LCD Projector
Hitachi cp-x300 will not go into advanced mode
I have tried from the remote and rom the device. I am not able to reset the LCD to ceiling mount.
  • FrankyJ Dec 11, 2012
    I am also not able to select the advanced mode. I scroll to it, but I am not able to select it.
    Problem Solver:
  • 9 Answers
I don't know that model but normally mirrored (ceiling) settings are in the basic menu. Some of the hitachi models won't go to Advanced mode or some of the image settings unless there is a signal that they are adjusting as you end up with settings for the RGB input and separate settings for composite (video via phono)
Posted on Jan 18, 2013
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Posted on Feb 03, 2008
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
fredcause
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Posted on May 07, 2009
Our LCD is ceiling suspended, upside down. When I was resetting the time for cleaning, I think I touched a button on the remote that turned the image on our screen upside down. I can't figure out how to...
1. Press the KEYSTONE button on the remote control. 2. Go down to Manual with the \/ or /\ button, then press > to select it. 3. Select V:INVERT, or H&V:INVERT, to flip the image.
Mar 04, 2011 | Hitachi CP-X260 LCD Projector
I have a Hitachi CP-RS56/CP-RX61/CP-RS57 projector that we just ceiling mounted. My tech spec is in the hospital and can't help me out. How do I flip the image that is projected?
ok the onboard menu built into the projector accessable via the remote or button on the projector... go through this menu carefully and read everything you will find the way to flip the image in there :) hope this was helpful.. thnx
Feb 25, 2011 | Hitachi CP-X345 Multimedia Projector
I have a CP-X300. The bulb has 1200 hrs on it. It has gotten a redish purple spot in the center of the screen. Do I need a new lamp or something more? Thanks
You have heat damage on one or more of the LCD units. They are not repairable and must be replaced to fix your fault. The cause is excessive heat possibly due to a blocked air filter or fan.
Feb 12, 2011 | Hitachi CP-X300 LCD Projector
Why Hitachi CP X300 projector periodically sound a 2 tone chime?
Data projectors sometimes make this sound when they are powered up. Is that when you hear it? If so it's normal and nothing to be concerned about.
If this is not when you hear it, please post more information since otherwise you're just asking us all to guess.
May 12, 2010 | Hitachi CP-X300 LCD Projector
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi CP-X300 LCD Projector Logo
43 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
