Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
Acts like the solenoid but replaced it and have the same problem
Crossing the terminals at the solenoid starts it every time.
Could this be the key switch?
  • Anonymous Mar 17, 2009
    engine wont start with key but will when i jump solinoid. tryn to check all three saftey switches but not sure how?
The dealer replace the time chaim and i put new stater motor and new battery i have problem to start,after 3 or 4 time when i tund the key start
Probably bad ignition switch where the key is. OR the line connecting to the starter solenoid terminal (small). Or could be a bad relay between the ignition switch and the starter solenoid terminal. Could be a bad starter solenoid, Yes, several instances of bad starter solenoids.
Apr 01, 2015 | Cars & Trucks
Yard man riding mower
By crossing the terminals on the solinoid you have taken this component out of the picture, so the problems has to be in the engine or the starter, if the auto deco valve in the engine is not working the engine will be sluggish to crank over.
Sep 28, 2013 | Mtd Garden
Toro wheel horse 13-38xl lawn mower won,t start, makes buzzing sound when key is turned on,checked solenoid with screw driver but will not start motor, tuned pulley under motor and wheel on top of motor...
If you crossed the two battery terminals on the solenoid and the engine did not turn over, I would check the battery terminals first to see if they are tight. Then check the terminals at the solenoid to see if they are tight. If all of this is tight and you are sure you have 12 volts at the solenoid, then your starter is bad.
Aug 23, 2013 | Garden
I have a 2000 chevy malibu ls. at first..we just thought that the battery needed charged..so we bought a new battery.. then it still wouldnt start..so we bought a new starter and replaced that..and it...
DO you hear a clicking when you turn the key to start? Solenoid relay make a click sound when energized.
If the solenoid is not mounted on the starter motor then it will be near the battery
The key switch sends power to the solenoid. the solenid is a big remote controlled switch,and it takes power from the battery to the starter motor
Feb 11, 2011 | 2000 Chevrolet Malibu
Ignition switch doesn't engage starter. For several months every 10-15 times that I attempted to start it it would click once and not start. If I waited a few minutes before trying it again, it would...
Does your ignition key have a small 'chip" in it, sometimes call a smart key? If it does, that may be the source of the problem. The "chip" is actually a small resistor that has to be read by the sensor in the ignition switch. Try cleaning the key with alcohol and see if there is any difference. Sometimes they get dirty and the sensor has a hard time reading them.
Dec 30, 2010 | 1996 Buick Park Avenue
I need help with my f150 truck. the silnoid (sp) was replaced then the started was replaced. now it won't stop turning over! what could it be? my husband is the one working on it...
Check back the wiring connection at the solenoid. Solenoid acts as a switch between the 2 terminals. When a solenoid engages, it makes a bridge between the other 2 terminals. There are 2 possible reasons: 1-Wrong connections cause bypassing the solenoid function controlling the connection from other terminals so current could continue flowing to the starter causing it keep turning. 2- Bad solenoid with a broken spring inside causing the bridge between the 2 terminals conducting a current all the time for starter to keep turning. If checking the connection correct then replace the solenoid.
Dec 24, 2009 | 2001 Ford F150 Styleside SuperCrew
Acts like bad battery but new
You have a bad ground connection no doubt. remove and clean the battery post real good and reinstall.
Sep 18, 2009 | 1997 Jeep Wrangler
1988 Lincoln town car: starter will not engage when attempting to start the car. I crossed over the two posts on the solenoid and the car started as normal. Replaced the solenoid. Did not solve the...
alittle vague about the 2-posts....both LARGE ones or the large one and smaller one.....here is something you may check since you said jumping the solenoid started the car....with help have someone turn the KEY to start...with a continuity light check the SMALL terminal at the solenoid...it should have voltage...if not it's you IGNITION SW.. or wiring....hope this helps you..GL
Jul 12, 2009 | 1988 Lincoln Town Car
Replacing starter solenoid
You may have hooked some wires up incorrectly. The smaller diameter wires on the small posts go to different items. One goes to the starter and the other to the ignition. Sometimes the little black bonnets that plug on to the terminals are marked. (S for starter and I for ignition.) You can also jump across the terminals to bypass the ignition switch to see if you even get power to the starter. Let me know what happens.
Mar 05, 2009 | 1988 Ford F 250
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
219 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
