Question about Wolf Range KFS-0-27-SCB-36 Gas Kitchen Range
I have a wolf 36' DF366 range/oven. The clock will not stay lit, when you try to set the time or use the timer it does not stay lit.
When you first open the control panel, the time is there, but it quickly fades away.
4 Suggested Answers
SOURCE: Wolf Model R364G has a delayed ignition in the oven
yes it will applie to to second owner.
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: wolf range 36'' gas range
this sounds as if your gas suooly pressure has dropped and the ignitor
does not light until a significant amount of gas is in the oven. check
your gas supply line for a bend or kink, also chec if the shutoff valve is
partially closed.
Posted on Aug 22, 2009
aquatom
  • 108 Answers
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
Posted on Oct 08, 2011
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
I have a ceramic top slide in range. The clock will light up when the clock button is pressed but will not stay lit. Timer works and all oven controls work as well as the cook top and oven. Any...
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
May 21, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do adjust the pilot on a wolf commerical oven
screw is next to the pilot tube where it attaches to the safety valve. unscrew to find the actual adjustment
Jul 26, 2012 | Wolf Range F0027WS36 Gas Oven
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
I have an old whilpool kitchen range and I moved and the timer buttons got turned. How to set the timer buttons to get the stove burners and oven to work, lost the manual.
if you have a clock where the hands go around and smaller start and stop clocks, here's what to do. set the clock to current time, push in the stop button and turn it until it stays in, then push in the start button and turn it until it pops out. try this.
Oct 15, 2009 | Whirlpool Ovens
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
Wolf Range KFS-0-27-SCB-36 Gas Kitchen Range Logo
42 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
Dan Webster
Dan Webster
Fred Sops
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
