Question about Ricoh Aficio 450 Copier
Printing labels on Ricoh 1224C copier
Need to know how/where to set printer for label insertion and printing. Thanks, Nancy
nancyjj37@aol.com
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Posted on Feb 14, 2009
How do you format lables to print properly on the richo e7000?
Printing labels is a pain! It is much easier to print using an A4 sheet with (say) 7 rows of 4 labels on.
I suggest you use the Ricoh support site
http://www.ricoh-support.com/Enduser/support/
May 07, 2014 | Office Equipment & Supplies
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
After each label I print the printer automatically advances 3/4 of the way through the next label. Is there a setting to stop at the end of each label?
I don't know the particulat incantations for this printer, but it sounds like the "form length" or "label length" is not set correctly. Normally the printer will advance to the beginning of the next label once the printing is complete. Check the menu or setup program for the label length.
Let me know if you can not find this and I'll research the exact commands.
Thanks,
Dan
Aug 12, 2010 | Seiko Smart Label Printer 100 Thermal
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Labels unexpectedly stop printing half way through a job
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Jun 02, 2009 | IBM Infoprint 6700 R40 Printer
Printing Labels
Sorry loose plug. All fixed!
Jan 06, 2009 | HP LaserJet 1020 Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
Apr 07, 2008 | Dymo LabelWriter 400 Thermal Printer
Ricoh Aficio 450 Copier Logo
1,001 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
