Question about Coffee Makers & Espresso Machines
When i whant to swich on my coffe machine it says selection locked, i try to clean but its everything the same.
  • 3 Answers
Has this been solved? Could it be it's still heating up? Beverages cannot be dispensed of temp is below 15degrees. Otherwise the sensor is probably defective.
Posted on Aug 21, 2014
3 Suggested Answers
SOURCE: I HAVE A EXPRESSO COFFE MACHINE MODEL XP4050
Just only I follow the instruction that I read in Fixya with citric acid and resolve my problem,
Thanks
Posted on Jan 16, 2009
  • 1089 Answers
SOURCE: COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Posted on Jun 20, 2009
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Hi
Jun 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Coffee coming out luke warm
Built in timer. I have a coffe perculator which swiches itseft off after 2hrs regardless untill I switch it back on again.
Feb 11, 2009 | Keurig B100 Coffee Maker
Thanks
Jan 14, 2009 | Krups Coffee Makers & Espresso Machines
I spilled a coffe on the battery side of my laptop
Hi Shema,
In which area do you live in? You can just call up any laptop repair service and tell them your problem and also ask an estimate for the repair. You can call up more than 2 sevices and compare the costs and fix it up.
Thanks.
Nov 03, 2008 | Toshiba Satellite A60 Notebook
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
