Question about Savin C2824 C3528 C 4535 Color Copier Drum B1809511
What does the code SC555 on a Savin C4535 mean
I have a code of SC555 coming up on my copier. What does it mean and how do I fix it?
4 Suggested Answers
  • 192 Answers
SOURCE: error code E-4
You only have part of the error code. You need to hold down the "." key in order to get the rest of the code. Since there is only 3 error codes that begin with 4, I'll post them here so when you find out what the problem is, you can attempt to solve it.
E405 - Transfer belt/drum charge roller position abnormal
E440 - Main motor lock
E442 - Drum charge thermistor abnormal
It's most likely not the third, as this one doesn't normally cause the machine to stop operating. The first two can be reset by turning off the main power switch for a few seconds, then turning it back on. This will clear the error, provided it's not a hard error (one that reoccurs during the machines warm-up cycle).
Just so you know, due to the age, parts for this machine are getting hard to get...
Posted on Dec 17, 2009
  • 183 Answers
SOURCE: My Savin C4535 says the front door is not closed
be sure that no other doors open first and ther is any code relevant with open door
Posted on Jan 18, 2011
  • 44 Answers
SOURCE: MY SAVIN 4700WD WIDE FORMAP COPIER/PRINTER/SCANNER
The error code is from the image density sensor, it may be dirty or not able to read the drum surface correctly. If it hasn't been serviced in a while a preventive maintenance will be needed. What is the meter reading on the unit at this time? Hope this helps.
Posted on Jul 17, 2011
Set key counter
Go into user tools and turn it off.
Jul 14, 2014 | Savin C4535 C3528 C2824 Toner Set 4 Colors...
How to fix SC555 error ?
Same way you reset 542 enter service mode and cycle power
May 21, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
On digital screen of copier code sc555...what is the problem approx. how much to repair?
fuser temperature problem code.IF YOUR MACHINE IS A RICOH,SAVIN.
GESTNER, OR LANIER YOU CAN TRY TO CLEAR IT YOURSELF.PUSH
YELLOW CLEARALL BUTTON THEN ENTER 1,0,7.STOP HOLD THE STOP BUTTON DOWN UNTIL THE SCREEN CHANGES ABOUT 3 SECONDS.PUSH THE ICON BOX THAT SAYS COPIER SP A NEW SCREEN WIIL APPEAR DO NOT TOUCH IT. TURN THE MAIN POWER
SWITCH OFFFOR TEN SECONDS.THE MACHINE WILL ATTEMPT TO
RESET AND WARMUP PROPERLY IF CODE COMES BACK YOU WILL
NEED SERVICE ABOUT 200.00 FOR FIRST HOUR PLUS PARTS IF NEEDED
May 10, 2010 | Office Equipment & Supplies
Savin c4535 wavey lines instead of straight lines on prints
What are you talking about...( nvram & dimm)????
Its a shredder....don't know which one you've got but most pcbs in shredders arn't that complex. The pcb might only cost $30.00 if its a consumer model...just phone the supplier.
Apr 22, 2010 | Office Equipment & Supplies
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
you will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Oct 07, 2009 | Ricoh Aficio MP1600SPF Copier
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Ricoh 3800c error code SC555
fuser related -- call tech to reset --- thermistors
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Savin C2824 C3528 C 4535 Color Copier Drum B1809511 Logo
94 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
