Question about Abit NF7 Motherboard
No audio from speakers--- Abit NF-7 v2.0 MOBO----
Installed mobo in a new Apevia case-------500 watt power---new cables----speakers worked before in older case----can not figure out what I have connected wrong if anything?--
    Problem Solver:
  • 8 Answers
Same configuration? (Same: Mobo, Processor, Hard Drive?) Just new case and cables? Do you have onboard sound, are you running a sound card, or perhaps you're plugged into a fancy graphics card sound port?. Try these configuration tips before you tear it all apart: Check your device manager in the system section and make sure your intended sound device is operational with no (!), or (?) alerts next to it. Reinstall any mobo, graphics card, or sound card drivers which run your sound device. AND finally, if you have more than one sound device on your computer (mine has all 3 options I described), make SURE you have the right one selected in your sound manager!
Posted on Jan 15, 2009
Mainboard: g31 m7 te - power: antec hcg750 - gpu: gtx560ti
No the mobo is compatible with the Power Supply, and GPU.
And vice-versa.
Mainboard fan???????
You mean the Processor (CPU) fan?
I'm guessing I guess, because computer case fans aren't on the motherboard/mainboard/mobo.
(MOtherBOard)
You're getting power to the mobo, but the question is how much?
1) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
http://206.108.48.60/app/en/mb/introduction.php?S_ID=363&tab=1
The mobo will support Intel Core2 Quad-Core processors. Depending on which one, you may be talking about Up To 105 Watts of power,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Quad-Core_Desktop_processors
This is why LED's can light, and fans may spin, but the Processor isn't getting enough power, so the computer will not turn on. (Processor isn't turning on)
Why?
1) Just because that Power Supply is new, doesn't mean it is good.
Sometimes you get a bad one. Test the three main voltages coming out, with a multimeter set to DC Voltage.
Need guidance post back in a Comment.
(An economical multimeter can be purchased, for as little as $8 to $12. I have seen cheaper. Available in a multitude of stores. An auto parts store is but one example )
2) You don't have the 4-pin ATX +12 Volt power cable plugged in.
Goes to the white square 4-socket hole connector, to the left top corner of the Processor socket.
(Motherboard installed in computer case)
3) REQUIRES -> TWO 6-pin PCI-Express power cables, for the Nvidia GTX560Ti graphics card.
The Antec HCG750 PSU has 4 of them, so no problem there, IF you have two of them plugged into the graphics card.
Both connectors of the 20 + 4-pin ATX main power cable's connector, need to be used. Biostar mobo requires a 24-pin ATX main power cable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
Post back in a Comment as to power cables plugged in, and DC Voltage test on PSU.
Regards,
joecoolvette
Aug 06, 2012 | Biostar G31-M7 TE Motherboard
The mobo continuously beeps (ram not properly placed). so i took out the ram, reinstalled it and it worked. recently i wanted to change rams, so when i installed the new rams the mobo beeped again (similar...
I am not sure if you have tried this, but take one stick of ram put it in the first slot. Try to boot if it beeps or not, power down and move to the next slot with the same chip (we are assuming this is a good ram chip). Repeat for every slot on the computer. If you have 1 or 2 slots that beep and the rest do not; bad slot on the mother board. If all slots beep, try a different chip (bad ram??). If no slots beep, repeat steps with each individual ram chip (you could have just one or two bad and causing all the issues).
Hope this helps
Mar 26, 2012 | Abit NF-M2S Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Abit IL9 PRO V1.0 mobo
Try updating your bios to latest revision then using the windows update with it set to get updates other than mmicrosoft products (like microsoft update used to do instead of windows update in XP) this may work. Seems to with alot of the older boards i build systems with
Jan 21, 2009 | Abit IL9 Pro Motherboard
Upgrading abit is7 mobo
You can upgrade to a celeron-D 3.2ghz or a Intel P4 3.4ghz.
Please rate my response. Thank you.
Jan 17, 2009 | Abit IS7 Motherboard
Powmax 4oo, no video to monitor
a dead short is the cause. or a bad ground., which wilkl lead back to a short
Nov 27, 2007 | Powmax LP-6100D (641272604024) 400-Watt...
NO POWER TO MOTHERBOARD
Doublecheck your powerswitch connection on the MoBo header. Also ensure that everything else on the header is seated correctly and tightly.
The case button may also be at fault.
You will then need to start methodical testing.
Sart with the PSU connected to a known good system. if that works you eliminate the PSU (You did turn tis on on the back didn't you! ;-)
If that Doesn't work try a known good PSU on this system.. If that works you for sure know it's the PSU that's dud.
If you have a spare Mobo try swapping the parts into that.
If it's a brand new board then it may be DOA, it does happen, but unlikely. Anthing else after the board actually gets power will mostlikely produce a beep code if nothing else.. Silence and not running is most likely one of the above.
If my solution was helpful please vote for me!
Nov 16, 2007 | Abit NF-M2S Motherboard
Emachines C2825 problem
If you know the motherboard is bad as well, you have two options. You can salvage the existing case and parts, and replace the motherboard and PSU. Plan on spending around $100-150 for both together. This assumes the CPU and RAM are undamaged. The second option is to buy a different "bare-bones" system, and transplant the parts into that one (CD/DVD drive and Hard Drive). Unless you have an exact replacement for the motherboard, you'll probably need to reinstall Windows. The easiest way around this is to install Windows onto a new hard drive, and attach your old hard drive as a "slave" or "secondary". These two options are centered around off-the-shelf parts, rather than buying a "brand X" computer. If you prefer "brand X", which includes an 800 # you can call, look at Dell. eMachines and Dell both produce low-cost low-quality systems, but Dell is better at it. For ideas on parts, look at an online retailer like NewEgg. For compatability, this is mostly a matter of using a tape measure and/or counting pins; they have low prices because they aren't there to hold your hand; if you would feel more comfortable with some hand-holding, which is fine, buy a new "brand X" computer. Lastly, keep in mind, the difference between a $500 computer and a $1500 computer is more than profit margin. If they don't say exactly what a part is, it's whatever was cheapest at the time. A $500 computer may be all you need, but it will have problems like this; whether that's best for you, is for you to decide.
Oct 01, 2007 | Intel D845GVSR Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Abit NF7 Motherboard Logo
137 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
