Question about Raleigh M60
Will the front forks on a raleigh m60 (1998 or older) fit on a khs alite 500
The khs alite 500 is about ten years old
  • Raleigh Master
  • 1,261 Answers
Very, very unlikely. Too many variables, including threading, inside diameter and length of the steerer tube, geometry of the fork blades, distance between the blades where the wheel slides in, diameter of wheel.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on Nov 21, 2016
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
There is no way to answer this question without measuring the fork steerer tube and/or trial and error. Good luck!
I have a 2003 Kawasaki en 500 looking for front forks have found forks but not the same year wanted to know if the 2002 forks would fit
Hi, Anthonyri303 after careful deliberation 4 out 5 Kawasaki Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Kawasaki EN500 Vulcan 500 LTD Service Manual
OEM Parts for Kawasaki
2002 Kawasaki Vulcan 500 Owner Manual
Kawasaki 500 Vulcan LTD
Kawasaki Vulcan
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 30, 2017 | 2003 kawasaki EN 500 Vulcan Classic
Front fork is locked up and won't move
Try to reinstall your fork.
Jan 22, 2014 | KHS XC 204
Front Fork is locked
Try reinstall your folk.
Here is simple introduction for reinstall bike folk.
KHS alite 150
when you took apart I hope you saved one of the bearings...take it to a bike shop and get the right ones. Then you're good to go
Jul 08, 2013 | Cycling
What is the firing order on a 1983 Honda Nighthawk 650?
Instructions
    • 1 Remove the front tire with the crescent wrench and set aside. Remove the nut and axle bolt from the tier and use the hammer to remove the axle bolt from the forks.
    • 2 Remove the securing bolt at the top of the fork on the handle bars. Slide the forks out of the fittings.
    • 3 Place the forks into the oil pan, bottom down, and remove the oil nut. Let the forks drain for ten minutes into the oil pan.
    • 4 Tighten the oil nuts and remove the seal from the fork fitting with a screwdriver. Slide the seal off the fork.
    • 5 Apply oil around the inside of the seal. Slide the seal onto the fork and press into the fitting tightly.
    • 6 Replace the oil in the fork following the manufacturer's recommendation.
    • 7 Replace the forks and the tire following the steps above in reverse order.
Jan 17, 2013 | Motorcycles
What kind of oil do I put in my older Raleigh M-60 mountain bike shocks? And how is it done? Thanks
Depends on the shock. different years came with different model shocks. Most of these were not designed to be user serviceable so most likely will not take any oil. Some of the shocks didn't use nay oil but rubber elastomers. This best taken into a bike shop and have them inspect it too see if it is even serviceable. If you don't know how to take apart a shock and reassemble it is not a good project to undertake. You need special tools, special oils, and replacement parts that will cost you far more than the shop will charge to overhaul the fork, plus they know what they are doing. Suspension is complicated and if not done correctly will fail and could most likely cause you too crash.
Apr 06, 2011 | Raleigh M60
Does anyone know if all of the components from a 2000 year model Raleigh Serengeti Mountain bike will fit on a 2006 Trek 4500 frame? I am looking at upgrading to a lighter frame, but like the components on...
They ought to. Bicycle components are quite universal. You may run into a part or two which won't fit (front derailleurs have to fit frame design [especially on full-suspension bikes] as well as tube diameter), and you must bear in mind that the geometry of the new frame will most assuredly be different, so your handlebars and stem may no longer be familiar or comfortable to you. Good luck!
Aug 26, 2009 | Cycling
Will Honda cx500 front forks fit on a honda cb250n
you will have to do some leg work to find compatable forks. here in toronto we have a few good places that stock tons of old bikes..im sure you can get a front end that fits, take off the trees with the forks and go shopping
Jul 03, 2009 | Honda CB 250 Motorcycles
Raleigh M60 Logo
155 people viewed this question
Top Raleigh Cycling Experts
85 Fiero SE
Level 1 Expert
dante
Are you a Raleigh Cycling Expert? Answer questions, earn points and help others
