Question about Kyocera FS3140MFP AllInOne Laser Printer
When I am scanning, I get Error type: SETTING on my kyocera fs3140MFP. The documents are not scanned
5 Suggested Answers
anantakumarj
  • 330 Answers
SOURCE: error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Posted on Sep 24, 2009
bimbabampish
  • 14 Answers
SOURCE: error printing scanned
some files may be corrupt: Best is try to reinstall printer software with original drivers to ensure that correct files are installed.
Posted on Nov 26, 2009
shawn38
  • 200 Answers
SOURCE: Our computer maintenance company was able to set
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
Posted on Jan 19, 2011
SOURCE: When i scan to email,
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Posted on Sep 12, 2011
Paper keeps creasing during printing. have moved guides out as far as they go
Creasing is usually caused by pare skewing so guides must be as tight as possible against the paper if it's still a problem you will need a new fuser a unit more than likely
Mar 12, 2015 | Kyocera FS-3140MFP Plus Black & White...
Error type :setting
if scanning to email it means you have one or more smtp settings wrong usally its the host address or authentication user and pass
if its to folder its either the ip of the computer is wrong or the login info is wrong
May 13, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Turn on confirmation page
you need to turn that on at the control panel. you cannot toggle that option in command center rx
Jul 17, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Why does my copystar FS3140 scan slow
default the scan settings to grayscale or monchrome and drop the resolution to 300dpi or lower
Mar 06, 2013 | Kyocera Copystar FS3140MFP Copier
Copystar CS-1820 Black and White Copier: need to scan a document to send as an attachment t...
You need to setup the email server setting through the command browser of the machine. open the explorer and type the ip address of the machine. under Email scanning setup the email server info and you will be fine.
May 17, 2010 | Kyocera Copystar CS-1820 Black and White...
Error type: Connect?? Can't scan.
Check your ip settings.. or if your scanning to file, make sure you have the directory path correct and have the right authentication credentials if its on a server..
Oct 05, 2009 | Kyocera CopyStar CS-3060 Black and White...
Scanner (c2520). all of the sudden, when trying to scan a document (we scan to PC...select a sender....save at user PC...and the message we are getting is:incorrect setting of destination folder. contact...
1. Use a web browser to go to the machine at the ip address that you assigned to the scanner to check the network connection.
2.you need to make sure that the computer you are scanning to has the "Kyocera scanning utility" installed and running in the background.
Make sure address book is running. In address book editor you can change the path of the destination forlder and the Id# that are linked together.
Hope this will help.
Jun 01, 2009 | Kyocera Mita Office Equipment & Supplies
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
Kyocera 2550 Scans but how do I OCR?
You can find documentation form Kyocera Printers here, though it barely mentions anything about their OCR feature:
http://usa.kyoceramita.com/americas/jsp/Kyocera/home.jsp
The OCR feature is only an image quality setting, producing a more black and white high contrast image rather than a grey scale image.
I'm using our Kyoceras to email the images to a server where "send mail" processes the image and runs OCRopus, an open source Google funded OCR project, to read information from the scan.
I'm finding there are many Virtual ReScan solutions, like Kyocera's OCR feature, VRS software produces OCR optimized images, though I haven't found an open source VRS project.
Jun 08, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera FS3140MFP AllInOne Laser Printer Logo
2,759 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
