Question about Fisher and Paykel Dishwashers
Fisherpaykel Dishwasher, DD602 need air pump
Model DD602 air pump no longer available. 1. any options to find part or some alternate 2. Seal is cut. does the pump go out if the seal is broken or can I replace seal only? Air pump is 3 yrs old
  • Fisher and P... Master
  • 3,247 Answers
If the seal is cut then I do not see any reason to believe the pump is also faulty. You can test if the pump is working or not buy listening to the sound when you start the dishwasher. The air pump runs for a few minutes at the start of the cycle. You can try and find pump for DD601 which might also work. Unsually the pump and the release valve should be replaced together for better operation.
Posted on Jan 27, 2013
SOURCE: maytag dishwasher mdb9600awb - loud pump
This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
Posted on Oct 06, 2007
  • 1073 Answers
SOURCE: Plugging the GE quiet power 3 dishwasher return line
remove the drain line and plug off the port on the sink that the dishwasher connected to, to plugit off black electrial tape wrapped arround the hole till it seals off will work
Posted on Apr 12, 2008
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Posted on May 27, 2010
Fisherpakel, DD602. How do I replace the seal oround the top. It has a cut in it.
The lid seal in DD602 works like a balloon. If the seal is cut then the air escapes and will cause the lid not to seal leading to leakage and flood switch trip which shuts dishwasher down.
See the following video.
You can buy the seal from this site but use the correct product code of your dishwasher to make sure you get the right part. The product code is engraved on the label located on the front under the top drawer.
Dec 11, 2012 | Fisher and Paykel Dishwashers
WHEN I TURN ON THE DISHWASHER WATER COMES IN BUT IT JUST HUMNS REALY LOUD. OPENED THE BOTTOM AND LOOKED AND SEE FAN BLADES STOP AND TURN STOP AND TURN SLOWLY.
Hi and welcome to FixYa, I am Kelly.
Just os you know there are 12 models of this dishwasher and you only gave a partial model number. It is missing several digits after the last G. The symptom you describe would be applicable to all 12 models.
There are a few things that can cause this symptom.
1. Debris in the motor pump impeller (Things like toothpicks or small bones / bone fragments)
2. The motor pump seal has failed letting water into the motor bearings.
^--- These are the 2 most common reasons.
Take a look under the motor pump assembly for the tell tale signs of water dripping onto the floor under the dishwasher. (stains or a circular soap pattern) If you see a water or a soap stain on the floor the motor pump seal has failed and the only remedy is replacement of the motor pump assembly.
See the link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209849&diagram_id=21603326#d21603326
Detailed view with 3 Views below link:
http://www.appliancepartspros.com/part_details.aspx?part_id=2616850
There is a possibility that the impeller is jammed with something but if the unit is 4 or more years old, most likely is the motor pump seal has failed causing subsequent motor bearing failure. It is best to remove the motor pump assembly for any attempt at clearing foreign debris from the pump impeller. Also look for a broken impeller blade during the clearing / cleaning process. If you thnk the motor can be salavaged make sure to lunricate the bearings with a paraffin based oil. We use the "Zoom Spout" Olier
http://www.appliancepartspros.com/Appliance-Parts/MAR-Zoom-spout-oiler-item-number-AP3695975.aspx
available at most LOCAL appliance parts sources.
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | GE 24 in. GSD5500G - Multiple Color...
We want to change timing belt in 87 acura 5 door intergra 1.6 and also replace all belts and water pump we do not know all parts to get could you give me a list? It has air conditioning too thank you for...
1) Belts: Timing belt, alternator belt, A/C belt, power steering belt.
2) Water pump and seal.
3) Timing belt tensioner- option.
4) Front crank oil seal-replace if oil is leaking.
5) Two camshaft seals-replace if oil is leaking.
6) Instruction on how to install the timing belt.
May 27, 2010 | 1987 Acura Integra
DD602 model. while running upper washer appears that the seal/gasket around the whole upper is not working as water makes it out of basin and on to the middle shelf, then drips on floor. is there a way to...
I had a air leak so that it would fail to keep a seal.
To find out what was going in a made up a hose, which I could put in line and fitted in a pressure gauge.  It showed that the pump was pumping, but the exhaust valve had a small leak.
Also, the pumps loose effciency as the butterflay valves wear.
Kit PH2 PN528148 Pump/Exhaust valve fixes this.
I reckon that this is the biggest weakness in FP dishwashers.
It would help kit of parts to repair solenoid & pump were available.
The coils just do not go faulty, so why replace them.
Jun 28, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Beeping and red light stating U3
Hi and welcome.
You posted your question in the DD/DS603 series section, but code U3 is usually seen on a DD/DS601 or DD602 series. When this code appears, most comon cause is that the machine is set in LP or LOW PRESSURE mode and needs to be set to HP or HIGH PRESSURE.
The fault is sensing water level too high in the drawer, which can also be caused by a blocked drain or inoperative pump. I can tell you exactly how to tell if the machine in in the wrong mode if you can tell us the correct model number. The machine's pump/drain system can easily be checked by putting the machine in diagnostic mode and running the drain pump.
Feb 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher and paykel dd602 dishwasher manual
i have a dd602 codeind u 3 i need sevice manual
Nov 30, 2008 | Dishwashers
Maytag quiet plus II - leaking water
Check under while the washer is filling and draining. You could have a loose clamp on a hose, the seal on the shaft may only leak while doing these. On the other hand, more times than not, rodents seem to enjoy chewing on washer catch basins.
Jun 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Mar 20, 2008 | Dishwashers
Dishwashers Logo
105 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
