Question about LG 32LH20 - 32" Class / 720p / 60Hz / LCD HDTV
LG 32LH20 colors distorted
My 32LH20 stopped working one day (assumed lightning hit, as other devices in the house were damaged as well). The power light would not turn on at all, no red standby, no response to buttons. I replaced the input board, EAX56738105(0), and I am now able to power on the TV, but the pictures and text have a rainbow of colors around them. This occurs on all inputs. Here are a couple examples http://imgur.com/a/ArE6Z I then attempted to change the power board to see if that was an issue. After changing the board, nothing had changed. What else could be causing this problem, other than the input board being bad? The replacement I ordered was off ebay, used. :(
  • maniac_beoul
    maniac_beoul Dec 11, 2012
    Grabbed one off ebay, I'll update when I try it. Thanks.
  • Erik Boeselager
    Erik Boeselager Dec 11, 2012
    Hope it works for you.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
The only thing I could think of is a tcon board, if that isn't what it's called by that tv, it's also called something like a LCD digital board to timing board. Usually it's right behind the display inside.
Posted on Dec 11, 2012
SOURCE: Digital Reciever Issues
Had same problem, fixed it by turning off at wall, wait 30sec, unplug antenna, turn back on, will say poor signal, click to another station at this point, should change OK. Switch all off again, plug in antenna, start up as normal, should be fixed.
Posted on Oct 01, 2007
SOURCE: Home theater won't respond to power button.
i had the same problem, just returned it to the store and they gave me a new one
jeff
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: Setup and Menu buttons do nothing on my LG LHT854
You need to press "Input" on the remote and keep pressing it until you get to the connection that you are using (e.g.: HDMI, etc). Once on that, you can use the setup screen. It took me several hours to figure that out.
Posted on Nov 26, 2008
  • 347 Answers
SOURCE: Have the LG LHB535 system and have significant
bad speakers trust me
Posted on Feb 26, 2011
dunnbiker
  • 8546 Answers
SOURCE: LG LHB335 player will not
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 05, 2011
LG plasma 60pv250. Green after lightning hit house. Turns black when I press menu. Can I replace a board or should I replace TV?
Personally I would replace the TV. There is no telling how many electronic components have been damaged, due to the extremely high voltage that lightening produces.
Oct 05, 2015 | LG Televison & Video
Hi my sony hi fi dvd music system stopped working after lightning strike. can i konw which part is affected?
Hello
It is not peredictable about which part/s have been damaged by a lightning stroke. Just see, there will be trillions of volts present, when a lightning stroke hit earth. All the electronic devices are meant to work by 110 or 230VDC. How can one say, which part to it might have been damaged due to lightning stroke?
A through checkup should be done. Sometimes, the repair cost may exceed by the price of a new one.
Jun 05, 2012 | Sony SC904CD Shelf System
Emerson TV Model #LC401EM2F Fix after lightning?
Lightning damage on LCD TV's can be a doozie. You really need to get it checked out by a qualified technician. I've repaired several TV's hit by lightning, most of the time the damage was limited to the power supply board. However, it is possible that multiple boards were damaged. If multiple boards were damaged, it's not worth repairing the set.
Jun 02, 2012 | LG Televison & Video
TV hit by lightning. Will Best Buy replace without questions?
Ask and see but I would not mention the lightening---if its 3 months old the LG warranty should cover the repair or replacement.
They will not know at all it was lightening unless you tell them.
"This thing just stopped working" they will either get it fixed or get you a replacement set.
Apr 01, 2012 | LG Televison & Video
My lg tv was damage by the lightning can it still be fix?
Hello
It cannot be predicted whether it can be set it right or not; because lightning will have trillions of volts when it hit earth. Our devices are designed to work for 220VAC the most. The repair circumstances will depend on the how strong it was hit by lightning. A through check is necessary to say whether it is repairable or not. Please contact an experienced service techinican and get his advice. OK.
Jun 28, 2011 | HP Televison & Video
I can't find manual for my LG television. I just signed onto Netflix and I want to stream from iPad to LG television but I'm joy sure what other attachments I need to make streaming happen. Model...
http://www.lg.com/common/product/support.jsp?localeCd=US&productId=32LH20&uri=/us/tv-audio-video/televisions/LG-lcd-tv-32LH20.jsp&categoryIdCms=3#
Dec 14, 2010 | LG 32LH20 32 in. LCD HDTV
Lightning strike
Lightning hits do some nasty damage to electronics.
Alot of times that type of repair is part of an insurance claim. The insurance company requires estimates and will repair them up to the cost of replacement.
If you arent dealing with an insurance claim on this I'd still recommend a professional estimate.
Lightning damage sometimes is confined to the power supply and once repaired could be fine bit in my experience most items that take a nasty hit are a write off.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 18, 2007 | TruTech PLV16320 Television
LG 32LH20 - 32" Class / 720p / 60Hz / LCD HDTV Logo
202 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
