Question about Nokia 5230 Cell Phone
Not getting switched on from fell down - Nokia 5230 Cell Phone
    Problem Solver:
  • 6 Answers
Is broke
Posted on Dec 11, 2012
LG Golden Eye CRT not working as it was fell down from Table what may be the probable reasons?
If the picture tube neck has got any crack, the TV wont switch ON. Check it. If the circuit board inside have cracked, the TV won't switch ON. Your TV need a through check up. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 24, 2014 | Televison & Video
Location of lean angle cut off switch
Depending on the make/model of your bike, there might be a "kickstand" switch (which prevents you riding off with your kickstand down) sometimes this can be faulty (or broken from a fall over) and prevent the bike from starting. I would check (bypass the switch) usually located near where the kickstand attaches to the frame, to see if the bike starts with the switch bypassed. If it does, replace (or remove) the switch. Depending on which side the bike fell, you might have damaged the kill switch (generally located on the right bar/clip-on). Basically carefully inspect the side of the bike that it fell on, look for any obvious signs of damage and then meticulously inspect that area for loose/broken wires/connectors. Do all the lights, instrument panel light up when the key is turned on? Check the battery connections. There are numerous possibilities, but use standard troubleshooting methodologies and you should be able to find or narrow down the problem. For future reference I think you were probably referring to the kickstand switch as opposed to to a "lean angle cut off" switch, which would be very dangerous to have on a motorcycle. Anyway, if you want/need more help. Post some more details such as; make/model/year, side it fell on, do the electrics (lights, turn signals, brake light, speedometer, tach etc.) work (or which don't & under what circumstances), does the started motor turn etc. etc. etc. Good luck.
Aug 16, 2014 | Motorcycles
My driver side window fell down & the electric switch won't raise it.l
If the switch is broken, you can put the switch down, short circuit closed first, if is bad, there is no way to the machine. Had better find a repair shop.car key programmer
Apr 05, 2013 | 1982 Porsche 911
What is the use of felling axes?
The felling axe purpose is to cut across the grain of wood as in the felling of the trees. There are different weights, shapes, handle types and cutting geometries to match the characteristics of the material being cut.
Feb 03, 2013 | Garden
Back window fell halfway down will not go back up. it will roll down, but only goes up halfway.
Sounds like it fell off the track.Remove door panel and speaker to get a good look inside door. There is a motor and a cable that moves the window up and down on the regulator. you could plug the switch in and watch it work . It could be the regulator and most are held in by rivets just drill them out and use nuts and bolts
Nov 01, 2011 | 2005 Chrysler Pacifica
Windos door does not down and lift up
if you press the switch and get no clicking or wirring noise then check your fuses, if they are ok then get your switch checked apart from that it could be your window mech motor. if you do get a wirring noise then it could be the motor has fell apart
Jun 12, 2010 | 1994 BMW 3 Series
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
I need to retrieve the em. flasher switch from inside the dash
If you mean the switch on the steering column, you will want to ramove the plastic cover on the column itself, and may have to remove the plastic trim by the speedometer. If the vehicle has an adjustible steering wheel, you may want to try pulling it down and see if that gives you enough room to get at the switch. Do you know where it fell? or is it just somewhere down there. Because it could be a task finding it if you dont know where it started. And you may just want to replace it if it is broken.
Mar 22, 2009 | 2003 Oldsmobile Alero
I have a V2Premier computer (Tower) the power button fell
Sure. You can even replace it with any momentary switch (Normally Off position switch) from radio shack or like places.
Jan 24, 2009 | Sony PCV-RS620G PC Desktop
Nokia 5230 Cell Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
