Question about Verbatim Store 'n' Go USB Flash Drive, 32GB Hard Drive
Verbatim store n go 64gb flash drive working fine until today it has 49gb of data on but will not show any of it in any pc i put it into please can anyone help
Mostly video files as i said working fine untill today i can put a new file on and it will show that but none of the other files and it still says it has 49gb of data on it
  • Verbatim Master
  • 27,725 Answers
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
It might take some time depending on the of the disk
be patient then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 you might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this or if i have missed the problem post a reply Hope this helps.
Posted on Dec 11, 2012
  • lleewill
    lleewill Dec 12, 2012
    im afraid it didnt work think i might just format it
  • Brian Sullivan
    Brian Sullivan Dec 12, 2012
    which operating system are you using windows 7 can be a pain with large volume usb and external hard drives sometimes if you leave the usb drive in restart your computer it will work again after you have restored it to its default status formatting it might work for the short term but the fault will remain and occur time and time again
SOURCE: Verbatim Thumb Drive problem
Download the following, I had the same problem and then this worked. Version 1.2.0.4
http://www.verbatim.com/support/support-article.cfm?support_id=858682BD-1422-1392-A8E8CBC9CA6CFE95&supportType=Download
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: verbatim usb drive 8 gb help
Sounds like the VSafe100 program is corrupt or missing. You can download it from verbatim.
Then make sure when you run the program you set the privacy zone size to 0 MB.
I'll bet right now your privacy zone size is set close to maximum only showing you approximately 3MB of space.
Posted on Feb 25, 2009
  • 103 Answers
SOURCE: How can I recover my Verbatim Store 'n' Go Red 4G memory stick?
Hi Karen
Follow the link bellow i have used this a couple of times and it seems to work well
http://www.filehippo.com/download_recuva/
Regard Alan (alstech)
Posted on May 10, 2009
Chinthakaj
  • 416 Answers
SOURCE: verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Posted on Jun 10, 2009
SOURCE: My flash drive verbatim 8 gb store and go is not recognized
I have the same issue with a 4GB Store N Go, works fine on my Vista PC at home but after copying a 3.5GB file to it and then later trying to copy that file to my XP machine at work, it keeps disconnecting and failing with, "The volume for a file has been externally altered so that the opened file is no longer valid". I really wanted the file off the drive, so what I tried was using "Robocopy.exe" (in restartable mode, waiting 5 seconds between each retry) from the Microsoft Windows Server 2003 Resource Kit. Once you have a copy of this, you need to open a Command Prompt, change into a directory (CD\<foldername>) where you want to copy the file to, then swap to the USB drive and use the following command;
Robocopy Drive1 Drive2 /Z /W:5
E.g.: If the USB drive is D: and your hard drive is C: with a folder on it called "Backup" (where you want to copy the files to).. do the following;
Start - Run: CMD <Enter>
C: <Enter>
MD Backup <Enter> (If the folder doesn't already exist)
CD Backup <Enter>
(Note: Assumes robocopy.exe is in your PATH or the same folder)Robocopy D: C: /Z /W:5
This will probably take quite some time, depending on the number of files/size... but it did work for me (eventually).
Posted on Jul 16, 2009
My mobile gt s5302 drow patan is five time worng then mobail user neme and pasword
1. Switch Off Your Phone
2. Press and hold Home Button + Volume Up + power on button
3.You will get four options and Select Wipe Data/ Factory Reset Option using Volume Key . Then Confirm by Select Yes Delete All User Data. Using Volume Down Key and Confirm it.
4 REBOOT NOW
May 29, 2014 | DURAGADGET Protective Case With Soft...
Hi, i have a problem with my cruzer flash,it was working fine,until last week, it's lighting up,but it isn't showing on the pc
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com Flash drives can become faulty if they are not removed fromthe USB port correctly. Please click on this link and follow my instruction torestore your flash drive :- http://www.fixya.com/support/r3598107-faulty_usb_flash_drives
Feb 14, 2011 | Acer Aspire 5735 Notebook
THE TRANSCEND JF V30 /64GB PEN DRIVE NOT OPEN, WHEN WE INSERT THE PEN DRIVE WINDOW ASK FOR FORMATING EVERY TIME
I have a transcend flash(pen) drive jf30 64gb.But it does not work properly.windows is unable to format.in the flash drive properties show "File system:Raw".
Nov 16, 2010 | Computers & Internet
I have a kingston datatraveller 200 64GB. I cannot access it and I get the message 2233 Pram. HOW can I read my files?
You can not. This is a damaged Flash Drive. The portion of the chip that holds the programming has become damaged. I had the exact issue. It had to be sent to a level 3 recovery company. Like ADR or Ontrack. I used ADR. Then you can send the device to Kingston for a free replacement but Kingston will NOT do a data recovery for you.
Jun 17, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I had verbatim 8gb jet flash.when i connect it pc it shows "please insert removable disk" why
My gues is the flash drive is not formatted to FAT32, or the USB port drivers are not installed. What operating system are you running?
Apr 21, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Hi.. i hav a problem with Verbatim 8 GB usb drive,
they have lifetime warranty but not for the data. this is a damaged boot sector programming on the flash drive. It can only be recovered via a Level 3 data recovery company like ADR or Kroll. I used ADR.
Dec 28, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
USB Drive no longer responding
Ok,
So it wasn't obvious damage then lets do the next step, Right-Click on My Computer, then select Manage, when the MMC opens select Device Manager on the left side, Open USB Devices and look for USB mass Storage controller. If it is not there then it's likely the controller board in the Verbatim shell is dead.
If that is the case, your best bet will be to drop by a local computer store and purchase an empty HDD enclosure to move the drive into.
If it does show up as a USB mass storage controller but not as a drive the problem is more likely in the circuitry of the HDD itself and you may require the assistance of a data recovery pro.
Chris
May 26, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
Verbatim 4gb
please use the CD came with the drive and formate it full. Reconfigure everything so that it will show the patition that you want in the window. Do not worry 'bout the Data. you can recover all by using data recovery software available on the net. Try google serch.
Oct 09, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim Store 'n' Go USB Flash Drive, 32GB Hard Drive Logo
278 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
