Question about Samsung Televison & Video
LE32R73BDR/XEU Freeview seems frozen, i cannot change channel but can still change volume etc
SOURCE: No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Posted on Oct 06, 2009
donzaca
  • 273 Answers
SOURCE: frozen screen on the dtv
in such cases may restart disconnect and reconnect and if the problem reinside check the local antenna signal may be failing
Posted on Nov 04, 2009
  • 8457 Answers
SOURCE: it seems to forget its
Tries tv and the box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The box to upgraded it softwares.Tv should be working again.If still have the same problems.Take ur tv backcover aparts and disconnection of the tv side manual control board PCB wire connection plug in that have like Power,Channel - +,Volme - + and Menu so on buttons switches.Turn the tv on and see if tv funtions correctly If yes than the tv manual cotrol buttons PCB board have to be change.If the manual contol board is diconnected from the tv Tuner signal board and have the same problems.Than ur tv have a bigger problems,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control PCB board or the tv Tuner signal boards for the replacement.
Posted on Apr 07, 2011
SOURCE: How do I adjust volume when tv is frozen?
Unplug the television. Check to see if the plugs are polarized (one bigger than the other). Sounds like if the plug was plugged in the wrong way could cause what we call a hot chassis. The tv is not properly grounded, it appears to be a grounding issue.
Posted on Feb 12, 2012
SOURCE: VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Posted on Sep 02, 2012
How to retune freeview tv
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Sony BRAVIA Televison & Video
Feb 12, 2012 | Digimate DGL32 32 in. LCD Television
It seems to forget its freeview channels and starts to run through every channel, interupting tv service provide by scart connection to talktalk box. First sympton is the sound volume icon appears on...
Apr 07, 2011 | Samsung B2230HD LCD TV
Re: Samsung : LE32R73BD
hi yes there is, put the tv in standby, on the remote control press info, menu, mute, power the tv will come on with service menu just select reset,, if this don't work you will need to replace the maniboard thanks
shaun
Mar 22, 2017 | Televison & Video
Digital channel mix up
your cable company is moving the channels around. they are doing a major upgrade
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
SONY TRINITRON DIGITAL TV KD-32DX4OU WITH BUILT IN FREEVIEW :_THE SCREEN HAS FROZEN ON ONE CHANNEL AND WONT CHANGE REMOTE CONTROL IS WORKING OK .ANY IDEAS ON HOW TO RESET ? TRIED UNPLUGGIN ETC THIS IS IN...
Unplugging should reset the it, but you may need to unplug it for a couple of hours. Try unplugging overnite. In the meantime, I'l look up the specific model and try to get you more details.
Dan
Apr 16, 2008 | Televison & Video
Freeview Box :(
This kind of interference can often be caused by remote pick up from energy saving lamps.
Mar 17, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Televison & Video Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
