Technics 110 Disk compact disc player constantly shows reading disks???
When I turn player on, it constantly says checking discs
  • Audio Player... Master
  • 1,258 Answers
1, It thinks a disc is in the unit, 2 it may have a dirty laser lens if a disc is in the unit. It need a service call to fix the unit. It could be a Pickup is burned out but that needs to be determined.
Posted on Dec 13, 2012
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
Benimur
  • 6966 Answers
SOURCE: CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
  • 88 Answers
SOURCE: it does not read CD
i suggest either your laser eye is contaminated or the laser has gone low in output
Posted on Feb 05, 2010
  • 141 Answers
SOURCE: Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Posted on Apr 07, 2010
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Technics sl- mc6 110 disc changer just keeps saying checking disc dosnt respond to of the buttons
this is a common thing to happen when the laser gets dirty or out of tracking , as it cant "see" any of the disks so it's "checking disk" forever
Mar 05, 2015 | Technics SL-MC6 CD Player
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
Apr 07, 2010 | Technics SL-PD887 5-Disc CD Changer
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Need Manual for Technics SL-PD827
Go to http;//audio.manualsonline.com
Jun 24, 2008 | Technics SL-PD8 5-Disc CD Changer
Oct 06, 2006 | Technics SL-MC6 CD Player
44 people viewed this question
 Grubhead
Grubhead
