Question about Dryers
Maytag medc400vwo. Heating element comes on with door open n placed on heat setting. Put on non heat setting and element turns off. I have replaced timer and cycle thermostat. Checked door switch ligh
    Sergeant:
  • 462 Answers
Has someone worked on it sounds like you have two wires mixed
Posted on Dec 11, 2012
  • Kathleen
    Kathleen Dec 11, 2012
    No one had worked on it prior to problem. When we replaced timer we took one wire off at a time and put where it belongs. Plus timer is marked where the colored wires belong. It's the same problem not a new one. This is frustrating. I don't want to have to pay someone to come look at it and repair it. They charge an arm and a leg and by time finished you might as well as bought a new one and I don't want to do that.
  • Gary Hill Dec 11, 2012
    id say your element is gone but cant say for sure
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
  • 27 Answers
SOURCE: Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Posted on Nov 02, 2007
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
aasc
  • 1606 Answers
SOURCE: LER8648LW0 Dryer. Not heating, runs continuously
One side of the element powers from the timer and the other side from the motor . Remove one wire from the element , and check which wire is not getting 120 V . Trace the wire NOT getting 120V and it will lead either to the timer or the motor , providing that the small t-stat looking piece (thermal cut-off) located close to the top of the heater box , shows continuity . If it does not , then pt # 3392519 is for it and the hi-limit t-stat . If you replace it , then replace both that come in the kit .
Posted on Jul 19, 2009
SOURCE: Maytag performa dryer PYE2300AZW
my dryer was working perfectly fine, but I think i had way too much laundry this day. anyhow, it just stopped working. the weird thing is the timer still runs I turn it to 90 and then it stops at 0. WEIRD!! i had my dad and husband take it apart, but of course we are reading the blueprints and tring to find matching numbers but no can do. we give up. HELP
sign the Dryer Monster
Posted on Dec 30, 2009
Mde3500 Electric Dryer will not heat
it sounds like the door switch itself is good but has a poor connection after the switch. That would explain why the momentary light flashes. The heating element will not start unless the door switch is sending a constant closed signal. Check your wiring & control board.
May 02, 2014 | Maytag Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Maytag dryer,MEDC400VWO,element will not turn off when the door is opened in the running running condition. I replaced the motor on advice from an expert and this did not help.
Check the heating element to see if the wire is broken and is touching the surrounding case. If the element breaks and "shorts out" it will sause the element to stay on.
Mar 29, 2012 | Dryers
I have a maytag mdb5130 that the soap is caking in the dispenser so not going out and cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Maytag Dishwasher
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Dishes don't dry
Hi. i would test the element first. this will be the likely issue.
First, open the door
and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
((The use of a good rinse agent will , also, produce a very efficient drying cycle as well)).
Sep 10, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Jan 21, 2009 | Dryers
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
