Question about Price Pfister Plumbing
What is the difference between a coolant check valve or a coolant temperature sensor? Or is it the same thing?
A check valve only allows flow in one direction. It will close if the flow tries to go backwards. I have never heard of one on a car. The coolant sensor is just that, and almost every car has one somewhere. Take a look in Chiltons Auto Repair manual to verify the presence or function of a coolant check valves. I would expect the coolant sensor to be easily accessible and not all that expensive- maybe $50 at the most, and screw-in like a spark plug, unless the Stratus' is extra special.
Posted on Dec 12, 2012
What is the difference between the Intake Air Temperature Sensor and the cool temperature Valve?
The Intake Air Temperature Sensor detects the temperature of the AIR being drawn into the engine intake. The ECM uses this do determine the proper fuel-air ratio as cooler air is denser than warmer air. The Cool Temperature Valve is actually called the coolant temperature sensor and tells the ECM the temperature of the coolant in the engine. The ECM uses this to control fuel delivery as the engine warms up (choke function), and it also uses this to control the turning on and off of the radiator cooling fans. In order to determine of the problem is the sensor or the fan circuit, a simple test is to start the engine and turn on the A/C. The cooling fans must run at all times when the A/C is on. If they are not running, it is not the coolant temperature sensor, but a problem in the fan control circuit.
Sep 20, 2016 | Cars & Trucks
Heater blows little heat
If my information doesn't answer your question I would ask, please provide year, make, and model. The first thing that I would check is the coolant level (radiator needs to be full). Check that the coolant is reaching normal running temperature (that will be between 200-210 deg.s). Check related coolant hoses to the heater core. Check hoses for defects (a clogged or pinched hose will restrict flow). Check coolant flow valve (shut off valve), at operating temperature test both coolant hoses and see if the temperature going in is slightly hotter than the temperature of the coolant going away (if the two temperatures are very different then the heater core could be clogged? I hope that helps, please let me know. Good luck.
Mar 01, 2014 | Chevrolet Cars & Trucks
On my 2003 Dodge Neon SXT I need help with a couple of things. (1) I need someone to send me a diagram showing exactly where the coolant temperature sensor is and where the oil pressure sensor is. (2)...
2003 Dodge Neon (non-Turbo)
The coolant sensor threads into the rear of the cylinder head, next to the camshaft position sensor. New sensors have sealant applied to the threads.
The ECT Sensor is a Negative Thermal Coefficient (NTC), dual range Sensor. The resistance of the ECT Sensor changes as coolant temperature changes. This results in different input voltages to the PCM. The PCM also uses the ECT Sensor input to operate the low and high-speed radiator cooling fans.
The combination coolant temperature sensor has two elements. One element supplies coolant temperature signal to the PCM. The other element supplies coolant temperature signal to the instrument panel gauge cluster. The PCM determines engine coolant temperature from the coolant temperature sensor.
As coolant temperature varies the coolant temperature sensors resistance changes resulting in a different input voltage to the PCM and the instrument panel gauge cluster. When the engine is cold, the PCM will provide slightly richer air-fuel mixtures and higher idle speeds until normal operating temperatures are reached.
The PCM has a dual temperature range program for better sensor accuracy at cold temperatures. At key-ON the PCM sends a regulated 5-volt signal through a 10,000-ohm resistor to the sensor. When the sensed voltage reaches approximately 1.25 volts the PCM turns on the transistor. The transistor connects a 1,000-ohm resistor in parallel with the 10,000-ohm resistor. With this drop in resistance the PCM recognizes an increase in voltage on the input circuit.
Oct 11, 2011 | Cars & Trucks
Overheating
OVERHEATING CAN BE CAUSE BY MANY THINGS LIKE FAULTY THERMOSTAT AND FAULTY RADIATOR PRESSURE CAP,TOO MUCH WATER IN COOLANT SYSTEM NEED 50 / 50 WATER AND ANTIFREEZE.LOOK FOR WATER PUMP WEEP HOLE LEAK, IF COOLANT LEAKING OUT WEEP HOLE WATER PUMP BAD NEED REPLACING.CHECK FOR LOW COOLANT LEVEL, YOUR RADIATOR OVERFLOW JUG SHOULD HAVE COOLANT AT THE FULL COLD MARK IF NOT KEEP ADDING COOLANT INTO COOLANT OVERFLOW JUG UNTIL COOLANT STOP DROPPING AND FULL COLD MARK, IF OVERFLOW COOLANT JUG WAS EMPTY RADIATOR IS LOW ON COOLANT.WHICH CAUSE AIR IN COOLANT SYSTEM KEEPING THE ENGINE COOLANT TEMPERATURE SENSOR FROM BEING SUBMERGE IN HOT COOLANT WHICH TURN ON THE COOLANT FANS.WHEN ENGINE COOLANT TEMPERATURE GET CERTAIN SET TEMPERATURE LIKE 190 DEGREES THE PCM AND COOLANT SENSOR WILL TURN ON COOLANT FANS, IF VECHICLE OVERHEATING COOLANT FANS NOT WORKING EITHER YOU HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR CHECK COOLANT FANS FUSE AND RELAYS. YOU CAN CODE SCAN CAR TO SEE IF YOU HAVE FAULTY PCM, FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR FAULTY COOLANT FAN RELAY.IF COOLANT FAN AND ENGINE COOLANT TEMPERATURE SENSOR OKAY,YOU HAVE CORRECT COOLANT LEVEL IN COOLANT SYSTEM, THERMOSTAT AND RADIATOR PRESSURE CAP BEEN REPLACED, YOU COULD HAVE BLOWN HEAD GASKET CHECK ENGINE OIL LOOKS LIKE MILK SHAKE HEAD GASKET BLOWED ALSO WHEN HEAD GASKET BLOWED YOU CAN DRIVE CAR SHORT DISTANCE START OVERHEATING AND YOU LOOSE ENGINE POWER SUSPECT BLOWED HEAD GASKET.
Aug 04, 2011 | 1999 Oldsmobile Alero
The check enging light comes on then goes off. I foud out the code po118 engine coolant temp circut high input. is it the coolant temp sensor. if so how do I replace it. It is on a 2004 jetta tdi
According to Autozone.com:
Because ECT (engine coolant temperature) sensor procedures vary depending upon their location, first locate the part. You may need to partially drain the engine coolant to prevent coolant spillage.
  • Disconnect the negative battery cable.
  • Unplug the ECT.
  • Then, unscrew it.
  • Reverse the removal procedures to install the new part.
  • Connect the negative battery cable to the battery.
    Related Parts:
Fig. Remove the coolant temperature sensor
The coolant temperature gauge sensor is a temperature-variable resistor, or thermistor. As coolant temperature increases, the resistance of the sensor decreases or decreases, depending on the type of sensor.
A1 and A2 platforms use a different type of circuit that A3 vehicles. On A1 and A2 vehicles, the circuit is a "resistance to ground" type. A3 vehicles use a "variable voltage" type, where a voltage is supplied to the sensor. Because of the circuitry design on A3 vehicles, testing of the coolant temperature gauge is limited.
The engine coolant temperature gauge uses a heat sensitive sending unit to transmit an electrical signal to the gauge. The sending unit is a heat sensitive variable resistor that is located on or near to the cylinder head and threads into an engine coolant passage. The sensors are a Negative Temperature Coefficient (NTC) type. As the temperature increases, the electrical resistance of the sensor decreases. As the coolant temperature changes, so does the resistance of the sensor. The gauge is calibrated within the operating range of the sensor and interprets the resistance value to display the coolant temperature.
Beginning with model year 1994, the engine coolant gauge and the Engine Control Module (ECM) temperature sensors were combined into one sensor with 4 terminals. The basic operation remains the same in that their resistance decreases as the coolant temperature increases, however the actual resistance values of the 2 sensor circuits are different. The electrical connector of the 4-wire terminal sensor ( 1 and 2 ) is keyed to prevent improper connection of the sensor's electrical circuit.
Fig. Beginning with model year 1994, the Engine Coolant Temperature Sensors combined the sensors for the ECM and the gauge into one sensor-1997 2.8L V6 sensor shown
Fig. The electrical connector for the combined temperature sensors is keyed to avoid improperly connecting the sensor's wiring-1997 2.8L V6 connector shown
Oct 17, 2010 | 2004 Volkswagen Jetta
It hesitate to start up in cold weather i have to give a pump of
There is a cold start valve srpay extra fuel at the start to assist the start in the cold weather. If it is not open during the start then this is why there is a problem. This valve is operated by an electric coil. Even checking the resistance reading, but the valve is still not opening due to being stuck. Power is only coming to the valve during the start and the temperature is cold reported by the coolant temperature sensor . If the coolant temperature sensor is bad reporting warm temperature then the valve will not open. The temp sensor is less expensive than the valve, so it is an economical way to tackle the sensor first. Good luck.
Nov 19, 2009 | 1997 Volkswagen Jetta
2001 Toyota highlander(4cyl),turns over,won't start afer few spins.Then,it will finally start.Has always started(fired)immediately- pumped gas a couple of times and it will finally start-runs fine-any...
Your cold start valve is not opening to assist the firing. It function is to provide extra fuel to ignite the all combustion chambers easily. When the engine doesn't have this extra fuel from the cold start valve, it will take a few times to get it going. The cold start valve is turned on at the time of starting only if the ECM get the signal from coolant temperature sensor saying it is at a preset level. When the sensor is bad, it can give a wrong value so ECM think that temperature is hot so not turning the Cold start valve. Replace this coolant sensor first, then the next thing is to check out the cold start valve.
Oct 29, 2009 | 2001 Toyota Highlander
Mercedes e230 1998. cold starting.
Mercedes has a cold start valve to spray extra fuel to assist the ignition when the temperature is cold. This is the problem with the cold start valve is not opened when it needed. There are 2 possible causes: 1- The valve is bad. 2- The coolant temperature sensor is bad.
The valve part is expensive and labor is not cheap. The first economic way to address is to replace the coolant temperature sensor. This sensor gives a different resistance reading as temperature changed. When it is bad, it give an erratic reading at cold temperature so the ECM could not recognize to give a signal to open the Cold start valve.
Oct 15, 2009 | 1999 Mercedes-Benz E-Class
High idle on 93 jeep yj 4 cly no vaccum leaks
This could be a few different things;1.Sticking throttle linkage.2.The choke may be not adjusted properly or sticking.3.The idle adjustment may be wrong.4.Somtimes valve clearances may bring the idle up.Check the throttle sticking and the auto choke first.These are the most common.Hope this helps
Sep 11, 2009 | 1993 Jeep Cherokee Country
Engine coolant temperature sensor
get a name brand sensor and double check with scantool under engine data for correct temp , if you can , use infrared temp gun and compare with scanner reading
Feb 19, 2009 | 2002 Ford ZX2
Plumbing Logo
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
