Question about Compaq Presario sr1403wm AMD Sempron 3000+ Computer PC Desktop
When i start pcits hang up show only compack logo also did not work key board there 4 i can not go 2 setup
    Scholar:
  • 191 Answers
Try inserting OS Bootable CD then also it won't work then remove RAM and Hard disk Clean them and reconnect and also remove & reinsert the CMOS battery.
Posted on Jan 13, 2009
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
Omnia logo hang on start up on samsung i900......... Nothing work then......
1. Turn off phone 2. Press and hold Send & End keys at the same time. 3. Without releasing keys tap soft reset with stylus 4. Hard reset menu appears ... just press send
Thanks for ratings.
Feb 26, 2011 | Computers & Internet
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Bios setup cannot detected 500gb sata Maxtor
hy on your maxtor hdd you have a jumper configuration you have to put your jumper in the good configuration so your primaries hdd is the one that have the exploitation system and the other one you need to set it to secondary hdd
bye and good lock
Mar 06, 2009 | Maxtor Hard Drive
Hang at startup (BIOS)
Yes laptops can work without battery.
If the laptop is hanging on Dell logo and entering into BIOS then normally it is HDD issue but you have already checked without HDD so might be it is RAM or Board issue.
You can check with PC 133.
Please check your Laptop with minimal boot once (by removing all external hardwares like modem,tv tuner or graphics if any) and if you are geting the display one of the devices is causing the issue whch could be diagnosed by connecting one by one.
Feb 09, 2009 | Dell Inspiron 2500 Notebook
Problem starting windows
Does the recovery CD give you the option to format your C drive? If not, you can try to get hold of a windows XP disk to do this.
Otherwise you might need to swap your hard drive
Mar 06, 2008 | Acer Ferrari 4002WLMi Notebook
How to format the sony ericsson k220i
my mobile Sony k220i this not working handfree
Jan 24, 2008 | Garmin eTrex Legend GPS Receiver
X7DAE at the time of boot stuck on logo
the broblem is probably your keyboard, since del doesn't work then this indicates that your keyboard could have some wires cut from inside the wire casing due to various reasons or the keyboard plug isn't well attached to the wires or have some bent pins.
my advice : go buy a new keyboard.
Dec 21, 2007 | SuperMicro X7DAE Motherboard
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
