Question about Weather King Heating & Cooling
My ac unit is leaking through the coil box, I cleaned the drain, but it still leaks from the side of the box. Could it be cracked? the unit is 9 yrs old
I pour water through the coils and it does drain properly, but when I get to the far left coil, the water does leak on side of box.
    Genius:
  • Weather King Master
  • 1,033 Answers
Could be a cracked condensate pan. this may require replacing the pan or there are sealing sprays on the market which you can buy at HVAC stores.
Posted on Jan 17, 2013
4 Suggested Answers
SOURCE: water leaking from coil pan that is cracked down center
maybe you can fill the pan a little with some type of sealent, like resin, that might seal the crack pan..
Posted on Jul 15, 2009
SOURCE: Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Posted on Jun 11, 2010
heatman101
  • 43501 Answers
SOURCE: Carrier Infinity AC indoor unit
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Posted on Jan 16, 2011
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Why is my lg portable ac leaking water from bottom of unit
There should be a drain pipe at the side or bottom of unit to run a drain line. Locate drain and clean it out .
Feb 26, 2018 | LG Heating & Cooling
My side by side drip"s
The water is from a blocked drain of the defrost, especially with the water off that's where its from. This tip i wrote will tell ya how to clear that drain http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
DeLonghi A120 12,000 btu ar conditioner Leaks
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Jul 10, 2010 | DeLonghi A120E Air Conditioner
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Roof leak from seal between AC unit and coach roof
Not very often that occurs but possible. If it has been running well for quite a while and not leaking, just double check that all 4 bolts are snug, but don't tighten too much and compress the gasket too much. I suspect that drip tray may be cracked, or drain holes plugged, and that is what is dripping inside. If it doesn't leak when unit is shut off, and it's raining, then I would pull the cover off, and check for blockage in all the drain holes. In order to properly clean 2 drains at evaporator coils (rear of AC), you will likely have to remove screws holding cover over it, and carefully lift it up and out of the way. Hard to see, but there is usually 2 drain holes in there, one on each side, and the tubes get plugged as well. Make sure power/hydro is off to unit for safety. If it does leak when raining, and unit off, then I'd say gasket needs replacing.
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
140 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
