Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Unable to clean 70 - Brother MFC 490cw Color Inkjet Multi-Function Printer
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
I need cleared (print unable 70) brother 3040cn
unable to print 70 is a Head problem or purging unit problem error code... better contact brother service
Sep 27, 2013 | Office Equipment & Supplies
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
Unable to clean, see troubleshooting & routine maintenance chapter in user,s guide
the waste pads need to get replaced. They are saturated with ink. Estimated cost is approx. $70 for labor and $20 for parts.
The whole unit needs to be disassembled.
thakns adi
Jan 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 70
Procedure how to reset the error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Dec 12, 2010 | Brother MFC-290C Printer
Hi error 01 on canon 5d mk 1. With brand new 70-200 2.8? Have read there is an issue on portrait shots but I am unable at this stage to be sure if it has only been an issue for landscape horizontal use or...
Error 01 is generally associated with camera unable to communicate with lens. Could be contacts need cleaned; since lens is new contacts on camera are more likely starting point for cleaning. But, common issue is failure of something in the lens, but that seems unlikely as it is new ... but it could happen. You might search for other Canon Error 01 comments/solutions. Failing a solution from that, time to contact SigmaUSA repair to have them inspect/repair under warranty.
Oct 03, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Sony lens 18 - 70 got stuck and it is unable to zoom
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2010 | Sony Alpha DSLR-A200K Digital Camera
Brother DCP-385C is not printing the menu on the printer is telling me unable to init.70
That error code tells us that the cleaning assembly can't move up and down properly. You need to unplug machine when the carriage is in the center, look over on the right side where the printhead parks to see if there is a paper scrap, clip, or something there stopping the cleaning unit.
Jun 25, 2009 | Brother DCP-385C Stylish Colour Inkjet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
203 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
