Question about Superstar SS-3900EGHPA CB Radio
My superstar 3900 transmits on one channel and receives on one ch
If I transmit on say channel 20, I have to turn my channel selector down 1 channel to receive clearly
  • Anonymous Mar 23, 2014
    The radio works fine, but the meter doesn't move for receive, or transmit.
    Any help would be greatly appreciated,
    Dan
  • 32 Answers
Ok! well i deffinitally know what the problem is. You need to play with the clarifier, i think all the way to the left is a "course and fine tune" knob. This is generally for use when talking on SSB. but may affect AM if its way off.
The clarifier lets you slide on the freq. some radios will go a full channel some will only go a little or above the center of the channel. You need to play with the clarifier, you probably need to turn the course a lot, untill the audio is almost clear on the channel you want to talk on, than use the fine to tune it in so it sounds like they are sitting right next to you.
what you should do is buy a Frequency counter, you got a nice radio, so the freq. counter wouldent hurt. lets say you want to be on channel 19. you would turn the clarifiers untill i read 27.1850 That would put you right on the money
Posted on Jan 13, 2009
  • Tom Zorn
    Tom Zorn Jan 22, 2009
    did you try this? let me know how its working
Superstar 3900 meter not working
Need more info, is the wires soldered on, has one broken, on board do you get a reading an not on meter? Could be meter or poor solder or broken wires. Because you dont get readings at all, tells me its more likely the meter or connections
Mar 23, 2014 | Superstar 3900
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
My Cobra CB Radio Receives Fine But No Transmit
is it a total no TX. or just not getting out very far.?
could have a broken mic wire. or the CB / PA switch may be in a wierd spot try moving it.. are you getting the Correct RX frequency on the channels.. ie are you getting channel 20 on acutal ch 20. and if you switch to ch. 6 are you getting ch 6? if you could explain more..
Dec 11, 2013 | Radio Communications
I can turn my Cobra 21GTL on and it goes right back off!
sorry disregaurd the wire colors.. on last post
1. Ground Shield
2. Audio
3. Transmit
4. Receive
5. CH. Up
6. CH. Down
wires can be any color. just matters what pin and pole of the switch they are one.
Oct 20, 2013 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Repeats selection and won't chage seletion. superstar 3600
Obviously your channel display must be working. I would assume the radio has sustain some harsh trauma to the channel selector itself possibly a drop.
Remove the speaker side cover looking down on the channel selector and its pcb board check connection and between the mechanical switch and pcb.
This may be as simple as a cold solder joint the problem is finding it.
http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif the schematic is for the 3900 which i believe are similar units.
Oct 24, 2011 | Radio Communications
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
A need help on my superstar 3900 the signal meter does not work on fm (rx) it key's up and stuff and is fine every where els plz email me with help charles_stewart2k9@hotmail.com
The FM has no forward modulation. You're radio will key up but you can't transmit on it. All cb radio are like that after conversion.
Jun 01, 2010 | Superstar SS-3900EGHPA CB Radio
Whats the wiring diagram to connect a sadelta es990 to a superstar 3900
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
Mar 30, 2010 | Superstar SS-3900EGHPA CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Mic hum
Yes, the wiring is different. Reverse the wires on pins 1 & 2, then reverse the wires on pins 3 & 4.
The wiring for you radio's mike is:
1- Audio
2-Ground (Shield)
3-Receive
4-Transmit
Depending on the vintage of your mike, the colors Uniden uses for these functions are white or yellow for audio, red is transmit & black is receive.
Jul 31, 2008 | Superstar SS-121 120-Channels Base CB...
Superstar SS-3900EGHPA CB Radio Logo
397 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
