Question about Epson CX8400 All-In-One InkJet Printer
Changing ink cartridge
How do I get the cartridge holder to set itself in the opening to change the cartridges??????
.................................wilo@ix.netcom.com......................
Press OK, and as it moves left and right, grab it so it will stay still under the opening. May not be the best solution, but it worked for me.
Posted on Jan 24, 2009
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i change the ink cartridge
    • Make sure the printer is plugged in and turned on.
    • Grasp the front top of the printer. This is the Scanning Unit Cover.
    • Lift the Scanning Unit Cover gently until you hear a click. The cover will remain open by itself.
    • Wait while the cartridge holder moves from the left to the center of the printer. The ink cartridges are located in the cartridge holder.
2. Then from there you just need to remove each individual ink cartridge and replace it with your newly purchased cartridges. Be sure to replace each one in it's appropriate location!
Jul 24, 2011 | Canon Pixma MP480 All-In-One InkJet...
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I cant change ink cartridge in my workforce500. the cartridge wont center itself so that i can open it and replace the ink
Epson has a Trouble Shooting Guide. Make sure that the 500 model number is showing on the top left. Select installing cartridges. Select Holder won't go to position. Then follow the rest of the instructions.
Here is the USER'S GUIDE, with instruction for changing the cartridges.
Hope this gets your printer working.
Good Luck
Feb 19, 2010 | Epson WorkForce 600 All-In-One InkJet...
Changing Ink Cartridge
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
Please rate!! Thanks, Prem
Jan 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
