Question about Asrock 775i65G Motherboard
Pci system management bus driver - Asrock 775i65G Motherboard
Pci bus 4 device 0 function 0
GO to the device manager and uninstall the PCI bus driver. Restart your computer. Windows will generate the generic drivers. Update the drivers. You can either do it manually or automatically. If you decide to update them automatically, then install RadarSync.
David
Jun 12, 2013 | Computers & Internet
Asus x55u usb 3.0 driver problem
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
May 20, 2013 | ASUS Computers & Internet
I am having difficulty obtaining drivers O 3000 N100 OS XP Base System Device PCI bus 5, device 6, function 2 Base System Device PCI bus 5, device 6, function 3 Base System Device...
Base System Device drivers are usually installed by what the manufacturer calls "Chipset" drivers. If you are running Windows XP, there is an Intel Chipset driver available at the Lenovo Support Page for your model. If you are running an Operating System other than Windows XP, I would go to the above page and compare the drivers listed there with what you are seeing in Device Manager. Install the ones that are missing. Hope this helps!
Mar 09, 2011 | Lenovo 3000 N100 Notebook
PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Jun 29, 2010 | Intel D845GVSR Motherboard
What is PCI bus, device 16 function 1 Code 28
While I do not know exactly what would cause your computer to display that code, I can safely assume that you are using a pci sound card if you are getting a pci error, and your sound is not working. In short, yes, the pci problem is almost definitely related to your sound problem.
Sep 14, 2009 | Microsoft Windows XP Professional
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Missing ethernet controller+Pci device+ sm bus controller
PCI Modem is your dial up modem, Ethernet Controller is your Network Card, and SM Bus Controller is your Motherboard Chipset drivers. There missing because your Operating System has Either Corrupt Drivers or they were never installed in the first place. Sounds like a fresh installation was done and nobody bothered to look in the device manager to see if any hardware drivers were missing.
Feb 07, 2009 | ASUS P5PE-VM Motherboard
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Aug 03, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Asrock 775i65G Motherboard Logo
20 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
