Question about InFocus LP 530 Multimedia Projector
The lamp does not light
There is no "life" at all when I try to start it. No controllamp is lightening. But the lamp seemed to be OK
  • clive pearson
    clive pearson May 11, 2010
    Unless you have ahd the lamp tested you can not goby looks hairline cracks in the capsule can be undetectable to the naked eye . however with out the gas element within the bulb to aid the arc process you got one duff bulb .. any good electronics shop should be able to help you .. as there is no element in this bulb normal multimeters can not measure it .. sounds like bulb to me at first instance other than that it may be a psu fault or ballast fault ... Regards Vortash
    Problem Solver:
  • 15 Answers
If your colorwheel and fans do not start spinning up, then it's not a lamp issue. The lamp will only strike if the colorwheel is already spinning. It's a safety feature to prevent burning the colorwheel. If your projector is completely dead ie no fans or colorwheel, then it's either the power supply or the controller board that has died, in that order.
Posted on Feb 20, 2010
Light came back on in older 18cu.ft. Frigidaire (freezer on top) refrigerator after lightening storm tripped a GFI plug on the circuit but no cooling or freezing No sound of motor running.
As the light works the supply is obviously ok.
It would seem to be time to find the reset button if there is one and try pushing that. If no reset button or it doesn't work the circuit and supply will need tracing through with a meter and/or a test lamp in order to discover the fault.
Apr 29, 2016 | Frigidaire Refrigerators
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
My projection tv display got really dark a few days ago. I didn't change any setting before it happened, but I tried to change them today in order to lighten the display, but it didn't help. Could a...
Yes,most likely the projection lamp life are ending.The tv projection lamp been inside the tv like 1 1/2 or 2 years?Daily tv watches like 4 or 5 hours regularly?Yes,than the projection lamp life are ending,tv do need a requirement of a new projection lamp.
Jan 06, 2011 | Samsung HC-P4752W 47" Rear Projection...
I replaced a lamp on a Zenith Projection LCD TV model # D52wlcd. The new bulb is working fine. However, the end of bulb life indicator light ( orange ) would not go off. Any advise on how to reset the...
Resetting the lamp time
After pressing the "?" key on the remote control in Stand-By mode, press the "9876"
and press the "OK" button.
And then three LED in the front is stop after flashing for a moment.* Lamp Life Time Confirmation
1. Method1 : Enter ADJ mode with using the remote control. You can be confirmed
because " Lamp Life Time XX hr" is appeared.
2. Method2 : With using the remote control offered to consumer if you press the
menu button continuously, OSD menus will disappear then press the "9876" and
press the "OK" button to enter ADJ mode you can see "Lamp Life Time XX hr"
Oct 13, 2010 | Televison & Video
Need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
Dash lights and reap lights
change fuse in fuse box for instrument panel the dash lights go out to tell you your tail lamps are not working
Jul 20, 2009 | 2001 Ford Escape
Pavilion dv6600 dimmed lcd monitor
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var experts = [{ avatar:'/Uploads/Avatars/68F2C5C.jpg',userName:'MNfisherman',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.7%, 799 votes', userUrl:'/users/mnfisherman',solutions:2295,experience:'Experience: Have knowledge with just about anything that is electrical, mechanical, or electronical & more!',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/ABF4CAB.jpg',userName:'localwonder',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'90.7%, 1460 votes', userUrl:'/users/localwonder',solutions:2913,experience:'Experience: I have yrs of experience dealing with many situations.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'avid101',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.8%, 264 votes', userUrl:'/users/avid101',solutions:795,experience:'Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'adirondacktr',"memberSince":'July 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.0%, 108 votes', userUrl:'/users/adirondacktr',solutions:363,experience:'Experience: hands on experience,training, mechanically gifted,and favorite reading material is how to fix things',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/4FD9B30.jpg',userName:'venexcsd',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.2%, 197 votes', userUrl:'/users/venexcsd',solutions:526,experience:'Experience: 50 years in the University of Life, plus an electrical engineering and computer background. ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/579A389.jpg',userName:'benwabnick',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.5%, 383 votes', userUrl:'/users/benwabnick',solutions:881,experience:'Experience: Been working as a computer technician for 10 years and have certifications in A+, Network+ and MCP',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'justaskjoe',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.8%, 964 votes', userUrl:'/users/justaskjoe',solutions:1787,experience:'Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/5446F1F.jpg',userName:'heavymetal77',"memberSince":'June 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.2%, 95 votes', userUrl:'/users/heavymetal77',solutions:311,experience:'Experience: I have a wide range of experience in many fields.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/1B34289.jpg',userName:'taran_2005',"memberSince":'November 2008',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.9%, 392 votes', userUrl:'/users/taran_2005',solutions:1752,experience:'Experience: If you have the desire to repair, follow my steps and be happy!!!! ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/0915BCA.jpg',userName:'komguy',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.0%, 177 votes', userUrl:'/users/komguy',solutions:301,experience:'Experience: I have been a Canon certified warranty repairman for 4 years. Always on top 10 national list.',brandType:0,brandName:'',brandIcon:'' }] BRAND_ICONS_DIRECTORY = '/images/Brands_24x20/{0}.gif'; var ctrl_experts = new Fixya.TopExperts(experts,$('ancAvatar'),$('imgAvatar'),$('ancUserName'),$('spnMemberSince'),$('imgRank'),$('spnRank'),$('spnRating'),$('spnSolutions'),$('spnExperience'),$('imgPrev'),$('imgNext'),$('imgBadge'),$('spnBrand'),$('ancRating'),$('ancSolutons')); ctrl_experts.render();
Jul 09, 2009 | HP Computers & Internet
Screen
You have a hardware problem.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 10, 2009 | Acer Aspire 5610-4648 Notebook
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
InFocus LP 530 Multimedia Projector Logo
169 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
