Question about Hoover Vacuums
In trying to repair foot pedal on my Hoover Windtunnel self propelled bagged vacuum, I got carried away and took apart most of the unit and I am still not able to get to the release..... I need help fixing the release lever AND then advise as to how to put the sweeper back together....Help!
  • Hoover Master
  • 18,409 Answers
This video should help you
Posted on Dec 11, 2012
Testimonial: "Thank you! I will try it."
3 Suggested Answers
SOURCE: The handle release lever (Part N. 38434-021) on my
You can buy Hoover Handle Release Lever 38434-021 at
http://partsreadyonline.com/item.php?ItemID=798
Posted on Jan 10, 2011
small6363
  • 18409 Answers
SOURCE: Hoover Windtunnel repair manual
click this link below to see repair video for self propelled mechanism
http://www.youtube.com/watch?v=K722IsUxjYM&feature=related
Posted on Sep 03, 2012
Sep 03, 2012 | Hoover Vacuums
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Dec 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I fix the carpet/floor switch on a hoover windtunnel bagged self propelled
The carpet / floor switch is a mechanical assembly. the bottom cover needs to be removed to expose the screws for the hood cover to be removed. then the switch can be accessed for repair
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
399 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
