Question about easybib.com
Do magnets affect the way a radish will grow?
Will the magnet affect the direction in which the radish will grow?
Will a induction stove top (magnetic) interfere with a 3 year old biotronik pacemaker
as the stove top works on a magnetic field that gets concentrated will metal appliances , it is possible that that magnetic will affect the pacemaker if near the stove
contact the manufacturer of the pacemaker direct or talk with the heart specialist for exacting advice
Oct 25, 2017 | Kitchen Ranges
My son put a magnet on the screen of his InnoTab2. Now it has a blank spot on the screen where the magnet was. Is there any way to repair this?
LCD displays are not affected by magnetic fields like CRT displays are. It sounds like the display might have been damaged by hitting it with the magnet and if this is the case the display will need to be replaced.
Dec 31, 2014 | Televison & Video
Im doing an experiment on magnetism.i need to find out how the distance of a magnet affects the size of its magnetic field
How about hanging the magnet from a scale. I am thinking of the one in my tackle box that weighs fish. Another way would be to place the iron on a scale and lower the magnet and see how much lighter the scale reads at various distances.
Feb 19, 2014 | Computers & Internet
Black "blobs" on PC monitor
hey there I think the problem is your magnet. Make sure to never keep magnets near your laptop. A magnet can erase the data off your disk and cause issues with your monitor. Anything that uses electro-magnetism to function will be affected by magnets.
Cheers mate!
Oct 16, 2017 | Dell Computers & Internet
Can lifting magnets affect someones pacemaker?
most lifting magnets only effect things that are directly under the magnet, and the magnet will be mostly concerned with the metal in the load. However, you should always post signs around to warn people who have pacemakers because it can cause problems if they get very close to the magnet
Jan 23, 2013 | Tools & Hardware - Others
Does magnetic case affect my phones screen..?
In some cases yes. It all depends on the type of cover bought for your device. If a cheap one then more than likely it will affect your screen.
If there is a soft cussion behind the magnet that touches your screen, there will be no problem with the case.
Hope this helps
Mar 22, 2011 | Eforcity Synthetic Leather Case with Belt...
How can i calibrate my phone
iPhone 3GS has a built-in digital compass that works just like a magnetic needle compass. The accuracy of digital compass headings can be affected by magnetic or other environmental interference, including interference caused by the close proximity of the magnets contained in the iPhone earbuds. The compass may need to be calibrated from time to time. iPhone 3GS alerts you whenever calibration is needed. To calibrate, hold iPhone 3GS in your hand and move the device in a figure 8 motion until the calibration screen disappears. The digital compass should only be used for basic navigation assistance and should not be solely relied on to determine precise locations, proximity, distance, or direction.
Nov 14, 2009 | Apple iPhone 3G
Calibre S affected by magnetic field
All watches are affected by magnetic fields.
Yes, your Tag watch will be affected. If it has been in a magnetic field it will need to be serviced to remove the magnetization from the movement parts.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Tag Heuer Link WJF2112.BA0570 Wrist Watch
My magnet cracked on my jbl sub woofer can it be fixed
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
Mar 24, 2009 | JBL PB12 Subwoofer
Magnets in the wall
magnet can affect color of your screen you need to relocate either your tv or the speaker. you can also remove the pink tinge in the upper corner of your tv by USING A MAGNET, how? by putting this magnet to the affected area then drag going out of your casing. prior from this you need to relocate your tv or the speaker to solve tour problem
Jan 01, 2008 | Toshiba 32A40 32" TV
easybib.com Logo
19 people viewed this question
Top easybib.com Computers & Internet Experts
David Payne
David Payne
Are you an easybib.com Computer and Internet Expert? Answer questions, earn points and help others
