Question about InFocus IN104 Mobile DLP Projector
In104 disassemble white dots
I have a 2001 Dodge Durango my sprockets dots are where they are supposed to be but the white dots on my chain or not do the white dots on the chain matter
I Assume you have a 4.7 liter V8, have you taken the chains or gears off yet, if so, did you line everything up before disassembly and lock the gears with a locking fixture and chock the chains in the guides? yes, all the dots and marks matter. it is an interference engine which means if the cams are out of time with the crankshaft, severe valvetrain/piston damage can result when started. get out the manual and go over all the marks and be absolutely sure everything is exactly lined up before trying to start. turn the engine over by hand at least 2 full revolutions to check for interference , then recheck all timing marks again. before cranking with the starter motor. timing is critical on the 4.7, if its off, bad thing can happen, please take your time and be careful
Oct 24, 2014 | 2001 Dodge Durango
Dmd chip
Not really a do it yourself. Chip is 3 to400$.
Jul 17, 2014 | InFocus IN104 Projector
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have moisture in my simmons red dot scope...How can I get it out I have disassembled it as far as possible and still can not get to lens.Model 851112
A red dot shouldn't be disassembled. If it has moisture in it, contact Bushnell (the owners of the Simmons brand now) at this site for warranty information.
http://www.simmonsoptics.com/ContactUS.htm
Nov 02, 2009 | Optics
WET
There is a good chance that the phone will work once dried...but make sure it is totally dry (try to absord all water ad give it a few days to dry out) before attempting to turn on. If you take it part and dry out the parts...even better.
Jan 11, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr: small mount of water contact.
Yes, once the dot turns red it will not go back to white. you can disassemble your self, but be careful. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Nov 24, 2007 | Motorola Mobility RAZR V3
InFocus IN104 Mobile DLP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
