Question about Samsung S860 Digital Camera
File error I would take pictures and it would be stored on the memeory card just fine but if i try to review the pictures later some of them would go blank and show "file error". What is the cause of this and how can i fix it. I am using a Sandisk 4GB memory card.
  • maguirec Apr 01, 2009
    took pictures and checked them, then the next day went to look at them and it showed file error where the pictures should be and the more i tried to find them and then turned the camera off, turned back on, some of the older pictures were gone and it says file error in the middle of those pictures
    President:
  • 2,976 Answers
Take off what pictures you can. Put the card in the camera and format it. Everything will be erased but, the entire card will be formatted to suite your camera.
Posted on Jan 13, 2009
  • 72 Answers
You may try to scan the memory card with this photo recovery software and then recover your photos.
Posted on May 07, 2013
File error
new memory card probably needed.... unless your already missing one.... Just take it in to some electronics store and get there opinion.
May 28, 2014 | Samsung Digimax S630 Digital Camera
How do i turn on the internal memeory on the S9600
the camera should automatically store onto the internal memory if there is no card inserted. if there is a memory card insterted it will automatically store onto that
Jul 01, 2013 | Olympus Fujifilm Finepix S9600 Digital...
I took a picture with my camera the other day, it had been working fine for 5 months, and then all of a sudden beeped and says memory card error, and I can't review any pictures. Connecting it to my...
Use a card reader to connect your card with the computer, as long as it can be detected by your computer, you can try some photo recovery software to rescue the files on your camera card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Oct 08, 2010 | Canon PowerShot A400 Digital Camera
"File contains no image data"
Try a new SD card. SD cards do fail.
The socket inside the camera maybe no good - bad connections.
The camera may have liquid damage - this causes all kinds of weird issues.
I try the cards in my computer reader. If they can be used all day there (I load and unload stuff randomly all day to test and then put the card in a drawer for a few days and check what I loaded later), the fault is likely the camera.
Apr 17, 2010 | Nikon COOLPIX L18 Digital Camera
How do you get pictures out of internal memeory onto memory card?
Press the Review button, then press the Menu button. Use up/down to highlight "Copy", then press OK. Select the desired options then press OK. Note that this copies, not moves. If you want to remove the originals, you have to delete them.
If you want to change where the pictures are stored, select "Image Storage" from the Setup menu.
Feb 23, 2010 | Kodak EasyShare Z712 Digital Camera
Picture on viewer fine..transfer to computer divided
It sounds like the file is corrupted. Try formatting the memory card in the camera. This will wipe the memory card clean and eliminate it from the being the problem. Formatting the memory is erase the memory card and you willnot be able to get the pictures off it after you format it, so make sure you down load all you the pictures you want befor formatting the card. Then occasionallly after downloading everything, format the card on a regular basis. This will help to keep the cards internal memeory from being fragmented. If formatting does not fix the problem, try another card (format it before use) if this does not fix it, take it to a local camera store and let them trouble shoot the problem or send the camera off for repair.
Nov 21, 2009 | Nikon D60 Digital Camera
Lots of file errors, O also now can't copy files off, says i/o device error
try using a memory card with 2GB or below
the camera might be having some problems reading the 4GB that you have
if you connect the camera to your computer and file error still appears that means that the memory card is corrupted and you really need to format it
before you do make sure that you have a copy of the files saved in the memory card
*formatting the memory card will delete all the files saved in it
go to MENU> SET UP > FORMAT
May 30, 2009 | Samsung S860 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Decode error! JPEG datastream contains no image.
Kodak has software that should be able to make sure those pictures are in JPEG format. Id use that at first instead of a third party program. Picture It! does some funny things to pictures and Microsoft discontinued that product line several years ago.
Here is a link to download it
There is a firmware upgrade too on this page. You should install that into your camera as well.
Jul 13, 2008 | Kodak EasyShare Z1275 Digital Camera
File error
First off... let's make sure you are doing one thing correctly. After you take a picture, it writes the information to your memory card. Make sure you allow it to complete that process _before_ you change and dial settings, go into the menu, or try to review it. If you interrupt it while it is writing to the card, the image will often become corrupt and give you the file error message. Next, I want you to format the card. Use your manual to find out the correct steps to follow. But be aware that it will remove all the information and photos from the card. It essentially erases the card so it looks empty and brand new to the camera. If the problem persists, you more than likely have a bad card. If it's still under warranty, try to return it. Otherwise, you may have to purchase a new one. Thanks in advance for reviewing me.
Jul 03, 2007 | Samsung Digimax A50 Digital Camera
Samsung S860 Digital Camera Logo
406 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
