Question about HP Compaq ProLiant ML370 G3 Server
Increase processing speeds ProLiant ML370
I don't want to purcahse a new server right now, my current one works just fine except that it isn't processing the information fast enough. Is there anything I can do to increase my processing speeds?
  • HP Master
  • 2,878 Answers
Only the obvious like CPU, RAM and network. You can check your specs against these possible configurations.
http://h18004.www1.hp.com/products/quickspecs/11450_na/11450_na.html
To be honest, don't see 64 Bit support so it may not make a difference, because of 32 Bit OS limitations.
Posted on Dec 11, 2012
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
  • 468 Answers
SOURCE: My HP Proliant ML370 server has no video. Can I
There is standard Integrated ATI Rage XL Video Controller with that server.
Posted on Apr 14, 2010
info2u
  • 596 Answers
SOURCE: HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
Posted on May 28, 2010
Mikenet2620
  • 106 Answers
SOURCE: I have a HP Proliant ML370 G3 server which was
generation 3 servers do not support windows server 2008 there are no drivers for this OS
i include the OS Matrix for you to confirm
Posted on Oct 29, 2010
info2u
  • 596 Answers
SOURCE: hiii.....windows server 2003 installed in my hp
You may need to reapply thermal grease to the cpu/heatsink combo. Over time, the grease will disapate and needs to be reapplied. Also, if your memory cards are very hot, you can add heatsinks to those to assist with cooling. And lastly, you may check to make sure that your power supply is the correct wattage for your system. A low 350W power supply trying to push a 780W system will create a strain on all component parts.
Good Luck
C2Solutions
Posted on Nov 09, 2011
Hp 6400 array controller don't post
Hi ,,
did you tried the offline diagnostics tools (Array Diagnostic Tool) and check it .
Mar 17, 2013 | HP ProLiant ML370 G4 Server
Hp proliant ml370 G6 ethernet controller, base system device and IPMI interface not configured properly
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Oct 20, 2012 | HP ProLiant ML370 G6 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
I have a server ML370 that won't display i have tried another VGA card but still no disply what could be the problem. HELP
Ifthe replacement video card is new or a functioning one then the monitor could be faulty. Try a different monitor.
Aug 17, 2011 | Compaq ProLiant ML370 G4 (374490421)...
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
Hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Jul 16, 2008 | HP ProLiant ML370 G4 Server
HP Compaq ProLiant ML370 G3 Server Logo
61 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
