I have tried to change my username and password in the configs part of the orange livebox. Ibut nothing happened and I can not remember the old username and password. I do not mean the part where you
Does anyone know how how it should be written etc. I have tried putting @fs at the end. Also I live in France so it is a French livebox.
  • 2,878 Answers
Most routers (including this one) have a reset in the back. Hold it in till it cycles. This will clear all custom settings and set original defaults.
I came across this. It might help.http://help.orange.co.uk/orangeuk/support/personal/232435
Posted on Dec 11, 2012
3 Suggested Answers
  • 27 Answers
SOURCE: i can't log in my router to config it..
its not actually a problem, all u have to do is to manually restart ur router and try again with the user name admin and with the password 123456 or 1234. hope it solves ur problem.
Posted on Apr 07, 2009
mail2pvs
  • 390 Answers
SOURCE: When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
Posted on Jul 07, 2009
Wanadoo router (Livebox) is "open"
Welcome to FixYa.
If you are in France, then chances are, your internet service provider is not ORANGE Broadband? (http://shop.orange.co.uk/broadband/)
Wanadoo router (livebox) has locked its router for their broadband service only or at least an affiliated one.
Try to use the CD that came with it to setup the connection and you will find out while entering your username and password, you will receive and error that says what you entered is not a domain used by Wanadoo.
Livebox will not try to authenticate over PPPoA unless the user has entered a username within a Wanadoo domain.
That is why there is no way to login to it's GUI (http://192.186...).
You can try http://192.168.1.200 or http://192.168.1.1 (this one should be the correct one)
There is no contact information for France since the internet service provider of Wanadoo operates only in the UK. (http://shop.orange.co.uk/broadband/)
I hope this information will save you time in searching for answers that do not matter.
Thank you for using FixYa.
Have a great day.
Jas247
Jul 24, 2011 | Computers & Internet
Change user name
Please indicate the Model of the router you are referring to.
If its Cisco, first do a no username xxx password nnn command on the existing configuration. Then on the global configuration mode insert a new command with the new username and password. See example below:
#configure terminal
(config)# no username old-username password old-password
(config)# username new-username privilege 15 password new-password
(config)# exit
# wr memory
May 05, 2011 | Computers & Internet
Netgear will not accept my password
Well, there are two possibilities: 1) You don't remember your password correctly 2) Some electronic failure messed up your password settings I recommend you to reset your router and reconfigure it, first turn off your router then reset your router by using a small pin or tooth pick and putting it in a small hole in the back of the router push just a little the reset button hiding in the hole for about 5 seconds and turn your router back on, the use default username and password to log into the router config, set up a new password and you're done. Have a nice day :)
Mar 30, 2011 | Computers & Internet
I can't remember my network password..i tried to go to 191.168.1.1 for the main Linksys site but nothing happens ?..tried "admin", no luck..please help
If you haven't changed the default values for username and password, tyr to leave lthe username field empty and enter 'admin' in the password field only.
Just my 2 cents...
Hope you are able to sort your problems out.
Regards, Carlos
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
The defaults
Type user NAME AS "admin" and password is "admin" or blank or "password"
Thanks for using fixya.
Jul 17, 2009 | Zyxel Prestige 334 Router
Orange Livebox working fine yesterday morning, now doesn't
have you check your phone line also go in to the admin settings and re put your username and password back in it should sort out as i've had the same problem if it don't work get back to me thanks
shaun
Mar 16, 2009 | Computers & Internet
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
May 26, 2008 | Computers & Internet
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Nov 26, 2007 | Powerline Ethernet Network Adapter
Want to disable pop-up window asking for password & username
if you are using outlook express.
1. open outlook.
2. tools menu
3. accounts.
4. select you account and press properties
5. select servers tab
6.in the incoming mail server...enter your account name and password. and check the remember my password check box.
if you forgot you account information. then you need to change the config within your router...to reset the router...press the reset button, usually located at the back of the router for at least 3 to 5 seconds.
Nov 01, 2007 | MSI Wireless-G RG54G3 Router
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Computers & Internet Logo
David Payne
David Payne
