Getting started with netgear extender WN2000RPTv2
Conect to SSID wirless wireless network 4695185382
wykidtech
  • 99 Answers
SOURCE: WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Posted on Mar 21, 2009
redhaze89
  • 854 Answers
SOURCE: I have netgear WGR614 it wont conect to the acual
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 09, 2009
justin217
  • 85 Answers
SOURCE: Can't get a wireless connection from my Linksys WRT54GC router
I think you have the router setup to not broadcast the SSID. Go to your router settings to change this option. By not broadcasting, it enhances security for your wireless network, because it looks like there's no network. I hope this helps!
Posted on Jul 15, 2009
router-user
  • 550 Answers
SOURCE: link the netgear wgr614v10 to linksys wireless adapter
First you will need to check the wireless settings of the router. Do you have any computer connected to the router ? If not then connect the computer to the router and open the set up page of the router, check the wireless settings of the router.
Once you have all the wireless settings of the router then you can try to connect to the wireless network on your wireless computer.
Posted on Apr 17, 2010
rcw1962
  • 2571 Answers
SOURCE: I have wireless network Netgear / lost security key
Log into your router ( default log in details can be found by googling your make) if you have changed the log in details, you may need to reset the router to factory default ( again, google this for a how to)
Go to wireless settings and then security ( or the other way around depending on your model) and your key will be there
Posted on Jul 31, 2010
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Gigabyte b49g wont link with wireless extender
first, Keep in mind that you bring the device into the same room as your wireless router.Use NETGEAR, Linksys Router.
second, Green LED on the extender is showing green to be able to get the optimum performance on your devices.
third, if not get it than just reset to factory defaults
then manually changed the security settings for your router .
Apr 14, 2014 | Gigabyte GN-B49G Router
Netgear ext
Once the range extender is in "discover" mode it will find your existing wireless network. It will then take the name of it and add '_ext' to it. giving you a second wireless network. For instance, if your wireless network was called my-house, the extender would create one called my-house_ext.
Dec 23, 2013 | Dell Computers & Internet
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
Apr 26, 2013 | NETGEAR CONSUMER New - Netgear Wn3000rp...
My wirless dissapear all the flasshing exept wirless line
Try RESETTING the Netgear back to the default setting and then configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
If this does not work then the Netgear routy is faulty, then you need a new wireless router.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 02, 2011 | NetGear WGR614 Wireless Router
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wirless adapter/router
Ususally when you have two different brand products, they seem not to work too well. Also, those type of adapters generally get bed reception.
Apr 04, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
Computers & Internet Logo
952 people viewed this question
David Payne
David Payne
