Question about Sony Cyber-shot DSC-T20 Digital Camera
The camera is not recognizing the original battery ?
Battery is charged and original . the camera told me that i have to use a original battery .
    New Friend:
    Problem Solver:
  • 5 Answers
Possible you put it in backwards
Posted on Dec 11, 2012
  • coyote_1
    coyote_1 Dec 11, 2012
    no the battery is correctly installed ;)
Why doesn't it recognize the correct battery?
hi,
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
Reset default camera says busy
Give the camera some time. Don't remove the battery till the reset is done. I hope your battery was charged before you started the reset.
If the battery runs out of power, you must charge it comlpete, before putting it in again. I hope the reset went well. If not only try a reset with a fully charged battery.
Dec 06, 2013 | Canon PowerShot Cameras
Gopro charging problems flashing
GoPro battery dead. Won't charge in the camera. No charge light comes on when you connect the camera to a USB. There's the scenario. Good tip on the GoPro battery shocking technique posted by Rabscuttle above. I discovered that my vehicle USB cigarette lighter adapter drains the GoPro battery when it's turned off. With the GoPro battery completely dead, the camera will not charge it. If the GoPro battery voltage falls below a certain point, the camera's circuitry is set to turn off the internal charger as if there's no battery in the camera at all. The recommended solution is to buy an external charger, which is able to charge a completely dead battery. The battery shocking method saves that expense.
Connecting a 9 volt battery to the GoPro battery for 30 seconds can give the battery enough charge to allow the camera to recognize the battery. A 9 volt battery from a smoke detector, a pair of jumper leads, and two straight pins is what I used to get my GoPro battery charged enough to allow the camera to recognize the battery and begin charging.
battery_zps064fc8f6.jpg?t=1415296281
img_2564_zpse9e14b4e.jpg?t=1415296297
May 30, 2012 | GoPro Cameras
I have a Canon 40D and have never replaced the original lithium battery as someone told me that rechargeable Li - ion batteries don't have a lifespan. My picture quality isn't what it use to be...
The battery does not affect the picture quality. The recharageable battery may affect the auto focus if the battery is low, recharging the battery should fix this problem. Otherwise the camera needs a service.
May 05, 2012 | Canon Cameras
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
I have a nikon D50 with the original lense. I have a battery that has been tested and works fine. when I put it into the camera the camera recognizes it there by telling me how much space i have on the...
Do you mean the camera can't works well with your new Nikon D50 battery? But how about your original battery. Maybe your new battery is not so compatible with your camera so the camera can't recognizes the whole information on the Nikon D50 battery chips.
May 09, 2011 | Nikon D50 Digital Camera
Digipower BP-BG1 doesn't work in SONY Cybershot 220
Take it back to best buy and get the original Sony battery.
Aug 13, 2009 | Cameras
Not charging
same thing happened to me and I've found 2 solutions:
1. Casio has recognized that this is a problem with the battery. If you call the support line and tell them the problem, they will send you a new battery for free. All you need is the serial code on the bottom of your battery.
2. This sounds crazy but it worked for me. Take a 9v battery and touch the connectors to the connectors of your np 20 casio battery. make sure to touch + to + and - to -. hold it there for 30 -60 seconds. put the np 20 back in the camera and put the camera on the dock. this will give it just enough charge that the charger will recognize the battery and start charging your camera to full.
Mar 17, 2008 | Casio Exilim EX-S600 Digital Camera
Battery won't charge
has to be replaced with original type of battery from dealer
Oct 30, 2007 | E-Machines eSlate 400K
Sony Cyber-shot  DSC-T20 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
