Question about Frigidaire Refrigerators
Fridgeidaire p/218888700 ice maker leake on bottomn no ice
Ice maker#24943710 came with refriderator
catriver
  • 878 Answers
SOURCE: ice maker leaking
Twodogs, I can't bring anything up with this model number but let me give you a couple scenerios of what could be wrong. The mold itself could be rotting out and leaking on fill, The fill valve in back of the refer might not be seating correctly and therefore you have an overfill. The fill tube might not be set in the trough causing it to spill over. Some models have a fill adjustment screw on the module of the ice-maker, I can't tell if yours does because of the incomplete model number. Catriver, post back.
Posted on Aug 09, 2006
SOURCE: water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Posted on Dec 05, 2007
  • 23 Answers
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Posted on Dec 07, 2007
jumptrout51
  • 3361 Answers
SOURCE: I have a Kenmore Refriderator with ice maker. It
The mold heater/thermostat is bad.
Solution; replace the ice maker.
Posted on Feb 21, 2009
  • 531 Answers
check water valve or i ce maker
Posted on Mar 31, 2009
Ice maker stopped working in a kenmore refriderator model 106 57032602
take the cap off the front of ice maher. turn the gears manualy in either direction about 1 turn put cap back. if that doesn`t work replace ice maker. MAKE SURE tube goes backon top of ice tray.
Dec 26, 2017 | Kenmore Refrigerators
Very slow at making ice
ice maker leakes on bottomn frigidaire #240437101
Dec 11, 2012 | Refrigerators
My ice maker keeps dripping water at the front by the control module
Make sure your refrigerator is level. Once your refriderator is level you should also check that your ice maker is level. You have some range of movement of the screws that attach the ice maker to the refrigerator if you loosen the screw and push up on the ice maker then re-tighten the screw.
Jul 20, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
OUR GENERAL ELECTRIC REFRIDERATOR HAS A LOUD HUMMING SOUND IN THE FAN OF THE ICE MAKER. HOW TO MAKE IT STOP!
sounds like the fan blade might be scraping ice or it has come off. turn it of. defrost eh ice - check the fan blade and try again.
koolman77 (refrigeration technician)
Feb 07, 2011 | Refrigerators
My ice maker dosnt seem to be working,refriderator working normally
Okay I will need more info. How old is the unit? Has the ice maker worked before? Has anyone touched the controls? Do you hear the water loading on the tray? Do you have a cold water dispenser? Are the tubes clogged? You know where I am going with this. The more info the better. Good Luck
Jan 07, 2011 | Refrigerators
My ice taste like metal and the filter does not need changing
I have a whirlpool refriderator that only makes ice. There is no filter in the fridge itself. The water line in the basement is copper, then it has a valve off of the main line. I originally had installed a stainless steel line running to the refriderator. The order of the ice can be described as a metal tasting taste. I purged the line prior to connecting it. I then replaced it with a pvc line, purging it all so. The taste of metal isn't there but it still has a small taste to it. Prior to having a ice maker, we made ice in ice trays with the sink water and had no issues. Can someone shed some light on this issue please.
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a fridgeidaire refridgerator with the freezer on top with an ice maker. it was made in 1999. the ice maker just stop making ice. any clues? Angelique
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 20, 2009 | Refrigerators
Water leaking from bottom of refriderator
Dec 07, 2007 | Refrigerators
dear ricurtsmith..
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerators Logo
35 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
