Question about Konica Hexar Silver 35mm Point and Shoot Camera
When i press shutter on hexar af the lcd shows 1/8 88 and camera
Freezes. I can only re set by taking battery out. it also sows e22
ginko
  • 19396 Answers
SOURCE: EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Posted on May 30, 2009
What batteries can i use instead of smashing batteries? Duracell ?
That camera takes lithium batteries. Duracell are DL123. Others are Energizer CR123 or Rayovac CR123A. The 123 is the key here. Other makers of lithium disposable batteries will use different letters, but the 123 is what you're looking for. They should still be available at Walmart etc. Panasonic CR 123APA 1B CR 123A Photo Lithium Battery Retail Pack Single
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
What batteries can i use in the samsung af zoom 1050
You will be looking for a 123A battery that you will most likely find at a battery store, or many an electronics store like Best Buy. Or you can google your camera model and order the battery online.
Battery ia blinking and in the square a captial H
problem with the shutter,shutter unit broken part,has to be replaced.
Mar 07, 2010 | Canon Sure Shot Z155 Caption 35mm Point...
Film will not advance
Broken "Shutter FPC" .
Needs replacement.
Mar 25, 2009 | Canon Sure Shot Z115 Caption 35mm Point...
My super sampler wont click after i take my firs shot??
Pull the string to advance the film. As long as your film sprocket holes are lined up with the sprockets in the camera, your shutters will fire the next time you press the shutter button.
Dec 31, 2008 | Lomo Supersampler 35mm Point and Shoot...
Nov 25, 2008 | Konica Hexar Silver 35mm Point and Shoot...
Camera goes into Shut Down Mode & Flashes the Letter H
Hey sonax,
This H error message means either the film is loaded incorrectly, or there is an internal malfunction in the camera. To determine if the film is loaded incorrectly you should take the film and the batteries out of the camera then reinstall the batteries and try taking a picture without film in the camera. If the camera allows it then the film was loaded incorrectly and I would refer to the camera manual for directions on how to load the film correctly. If the H error message persists then there is most likely an internal malfunction and I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon Sure Shot 65 35mm Point and Shoot...
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
LED's not working
Hav you tried changing the battery?
Jun 07, 2007 | Kalimar K-90 35mm 35mm Point and Shoot...
No picture
it seems that the flex ribbion cable from the camera body to the lense assembly is damaged. A good repairer can replace it.
Oct 28, 2006 | Samsung Maxima 120Ti 35mm Point and Shoot...
Konica Hexar Silver 35mm Point and Shoot Camera Logo
128 people viewed this question
Top Konica Cameras Experts
Robert A. Watson
Robert A. Watson
Are you a Konica Camera Expert? Answer questions, earn points and help others
