Question about Mitel 3300 Mxe Controller Unit Cabinet 50005080ra With 2 T1/e1 Module System
Mitel handset timeouts during call transfers; no error on the circuit, controller or the switch? curious...
... no error on the circuit, controller or the switch? curious...
2 Suggested Answers
ynotphone
  • 192 Answers
SOURCE: Mitel 5220 Electronic hook Switch?
The only electronic hook switch that I know about is on the 5330/5340 series phones, with the cordless headset from Mitel.
Here is a link to see what they look like... I have several installed at sites and the customers love them, no more handset lifters are involved. http://www.mitel.com/DocController?documentId=25305
Posted on Sep 19, 2009
How do you auto answer using a Savi W740 Handset on a Mitel 4250 Phone without pressing the Multicall Button?
You neet the Plantronics HL-10 Handset Lifter kit. Sold bundled with certain SAVI models and sold separately for approx $50. Contact your Plantronics dealer else get it from Amazon
Jun 19, 2014 | Mitel Lands Phones
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
Mitel 5330 hookswitch will not release call and will not ring
Sounds like your hookswitch might be defective or in need of cleaning. With Cisco phones, you can disassemble the phone and clean the hookswitch circuit contact, and reassemble the phone and it often solves the problem. Not sure how easy this is to do with a Mitel handset but maybe worth looking into.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Oct 18, 2012 | Mitel 5330 IP Phone
Handset on Mitel 5340 IP phone with bluetooth has no dial tone but has dial tone on speaker. Bluetooth signal is fine. Help.
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
Jan 07, 2011 | Mitel 5340 IP Phone
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Jul 24, 2009 | Mitel 5220 IP Phone
I just figured out what you ment
Possible Cause Action
The SMTP server is not in
service.
Check with the network
administrator.
IP address of the SMTP
server is wrong.
administrator and enter the
correct IP address.
Port number is wrong.
correct port number.
A timeout condition occurs.
Set a longer value for “SMTP
Connection Timeout.” The timeout
value depends on the
network’s traffic conditions
and load on the FTP server.
The network is disconnected
during file transfer.
Send Ping from PC to the controller
and SMTP server to
check to see if both parties are
connected to the network or
not.
For any clarification on the procedures.
See “User’s Guide
[Network Scanner
Operations].”
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Mitel 3300 Mxe Controller Unit Cabinet 50005080ra With 2 T1/e1 Module System Logo
29 people viewed this question
Top Mitel Computers & Internet Experts
rey francis basa
rey francis basa
danoyachtcap
danoyachtcap
Jay Plesset
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
