CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks. The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK. Time Regulation Tip: On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -. FRROM MY PERSONAL SHOP NOTES: If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1. NOTE: Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk. Keep A Regulation Record: Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps. Date: +/- in min: How much adjust in Degrees +/-: Personal Notes: We recommend logging only the times the clock was wound, and any time the clock is regulated or reset. Times of regulation will include any time the clock has exceeded a 3 to 5 minute error. Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended. Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set. TEMPERATURE and SEASONAL CHANGES Temperature fluctuation can affect the time-keeping abilities of your clock. Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements. SPECIAL NOTES: REGULATION TENDENCIES It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively. One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes. If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made. How to Calculate the Adjustment: Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations. Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Are you asking about a Winterhalder & Hofmeier clock? If so, what model are you asking about? You can add the model information by choosing Comment and typing the information.
If you do not know the model of the clock, if it is not a tall case (grandfather) clock and you can transport it easily, I suggest you take your clock to a reputable clock repair shop in your area and ask one of the knowledgeable people at the shop about setting the time and winding your clock.
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
Hour, minutes and second hands tell the time in relation to the day time light through until dark. The small round clock perform a similar function only that the grade meters appear different describably. The small clocks measure time by assuming the time in four quadrants of fifteen minute intervals where each intervals on the quadrant is symbolic of North East South and West as in compass directions. Every fifteen minute of the small clock indicate being within a compass measure zone tchnical measure of time of day in relation of geographic direction. Unlke telling the time with the big clock without consideration of the situation of the timer teller. The small clock is designed to tell the time in reference to the direction of the time teller, a feature which would have required compus together with ordinary watch to ascertain what the small clock attempt to provide all in one watch.
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry.
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
Citizen Weather Data Clock Settings. To set time press and hold for 5sec "set" button Use advance to add days, years, hours seconds. Press SET to hold.
