Question about Coby MP-705 Digital Media Player
Coby mp3 mp-605-4g is not recognized by any computers
Hi, i am trying to get my computer to recognize an mp3 player with no luck...it doesn't work on any computers. i tried the coby website for firmware, but this model is not there. can you please help...model no: mp-605 and it's a 4 gig.
thank-you
  • 6 more comments
  • Anonymous Jan 26, 2009
    i have the same problem
  • Anonymous Feb 06, 2009
    This player is a piece of garbage!
  • song379 Mar 08, 2009
    coby mp3 mp-605-4g is not recognized by any computers
  • Anonymous Mar 10, 2009
    i cant get it to regonize the any computers can i get some tips or info on it.....?????
  • the_dekkers Mar 27, 2009
    My Coby was only a few weeks old and all of a sudden it wouldn't turn on. It is the same model as the others......coby mpe mp-605-4g
  • Anonymous Apr 07, 2009
    I have the same problem, none of my computers will recognize it. It doesn't show up anywhere in my computer nor in the device manager. This model doesn't even appear on the Coby site!
  • ccc123344 Apr 26, 2009
    tried cobyusa.com and this model is not there. tried to get newer firmware due the the issue of power button.
    where to get firmware for this model coby mp-605 4GB?
  • Anonymous Mar 16, 2014
    coby mp556-4g does not recognize mp-4
I have the same problem. If you turn the unit over, you can see a small hole on th bottom right hang side - (next to USB symbol) - The RESET button is located inside. If you insert a small paper clip and press the button for approx 20 seconds it should function again.
Works for me
Posted on Dec 04, 2009
This solution only relates to the Windows Operating System.
You have to plug it in to a USB port preferably one at back off computer and you must have Administrative privileges because a normal user can't access system settings. Now right click on the "My Computer" icon. Next click "Properties", then "Hardware" and finally "Device Manager". Once in "Device Manager" scroll down to "Other Devices". Right click on the icon with the yellow exclamation mark or question mark. Then click "Update Driver". This should pop up a "Hardware Update Wizard" window. Instead of clicking "Install The Software Automatically" click the "Install From A List Or Specific Location". Hit "Next", then click "Don't Search. I Will Choose The Driver To Install". After mark sure "Show All Devices" is highlighted which it should be, click "Next". Now finally click something along the lines of USB Media Player or around that. Ok click "Next" once again and wait a little while. What this is doing is installing the driver(s) for your device. Your done click "Finish" to exit.
If your MP3/4 player still isn't seen by Windows it could be your computer or your device's "Firmware". Usually this solution is successful since I use it for any device that is not read by PC.
I know my iMac with Mac OS 9.2 reads this MP3 player fine.
Anyways if you can't fix the device this way then I don't know what else to say.
Like I said though sometimes it might be the drivers for your device.
I hope this helps anyone who needs it.
Posted on Apr 04, 2009
No mamezzz
Posted on Sep 09, 2009
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
Computer (Windows XP) does not recognize the Coby MP-C7085 player
On the MP3 player, go to settings > system, put the USB mode to MSC, then reconnect to the computer, computer will read, the device is currently on MTP and your computer doesnt have driver so that is why its not recognizing.
Aug 29, 2011 | Coby MP-C7085 MP3 Player
Good morning today I come to your help, I recently bought a coby MP620, but the moment I attempted to use it could not. I connect and my computer does not recognize and no sign of that charge I come...
Hi Linares,
Here are some steps that will hopefully fix your problem.
  • First I would attempt to restart your computer with MP3 player plugged in the USB.
  • Then once restarted, Locate the MP3 Player under "MY Computer". The MP3 player will be listed as a "Removable Disk".
  • The Coby manual suggests that you use Windows Media Player 11. You can find that here:http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
  • You can find the Coby manual here: http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
Good luck.
Mar 05, 2011 | Coby MP-610 MP3 Player
Computer does not acknowlege the hardware MP3 coby 610-4G
I can help you with your Coby 610 mp3 player.
Usually, a firmware upgrade / replacement will allow your computer to see your mp3 player again.
Following these instructions for fixing your Coby Mp-610 MP3 Player will replace the internal programming of your mp3 player, and allow your computer to recognize it.
I hope that helps.
May 06, 2010 | Coby MP-610 MP3 Player
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
Computer doesn't recognize mp3
Nov 22, 2009 | Coby MP-610 MP3 Player
Coby MP705 not being recognized by computer.
You need to plug it into a USB 2.0 port. The 1.0 (or 1.1) standard does NOT work.
Nov 20, 2008 | Coby MP-C7085 MP3 Player
Computer will not recognize my Coby MP-C7095
i know how to , you just go on your mp3 and go to settings and go to usb connectiona and then you switch the thing it says two options pic the other one simple as that ;D
Dec 21, 2007 | Coby MP-C7085 MP3 Player
Coby MP-705  Digital Media Player  Logo
5,329 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
