Stand needs to be removed for wall mounting.
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: Olevia 227V lcd
All you need to do is remove the two long screws on the back of the tv panel just above the stand, then the two short back panel screws AND the three short screws just above the two panel screws and the stand will come right off. DO NOT remove any of the other screws in the perimeter of the back panel. There is no need.
After much trial and error this is the correct and EASY procedure for this apparently troublesome task. Good Luck !!
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
SOURCE: how do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
SOURCE: removal of flat screen pedestal so I can wall mount tv
There a 4 set screws on the back of the TV. There is actually an arrow pointing down to show you what direction the pedestal. Remove thesze screws and the pedestal comes right off.
