Question about Kyocera Tk-352
Check waste toner box Kyocera Tk-352 - Kyocera Tk-352
krizanto81
  • 65 Answers
SOURCE: how to clean waste toner bottle
Disposal Tank is on the Process Unit... you will have to remove the screw on the left side then pour it out on the bag...
Posted on Oct 14, 2008
krizanto81
  • 65 Answers
SOURCE: Waste toner on Kyocera 1820
open the front cover, pull out the process unit... then unscrew the left side of the waste disposal tank (the opposite end of the toner cartridge)
Posted on Oct 20, 2008
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Posted on Apr 14, 2009
SOURCE: How do i empty the waste toner on Kyocera KM1500
Open the front door, Lift the plastic cover, you will find the kit of toner ansd drum. Yhe waste toner is in the end of the kit. You will find 01 screw in each rear side of the kit who holde the cover of the container of the waste toner. You must empty the container (extract thre waste toner).
Posted on Jul 22, 2009
What is the waste toner box
The collection box for waste toner. When making a copy or a print not all of the toner that is put on the drum gets used, during the cleaning stage of the process that very small amount of toner is removed and sent to the collection box. Depending on your make and model there is a scheduled image count that the box is replaced or emptied at. If you try to empty it yourself be careful!!! Toner is the finest dust you have ever seen and can become a large cloud in the air (landing all over the place) if not handled properly. And yes it will go through a vacuum cleaner bag and into the motor. Service techs have vacuums that are made specifically for toner.
Aug 14, 2014 | Kyocera Tk-362
How to scan on TK-352
you can download the manual from this link directly:
http://www.kyoceradocumentsolutions.co.uk/dlc/gb/documentation/usermanual/fs-c1020mfp_aog_eng.-downloadcenteritem-Single-File.downloadcenteritem.tmp/FS-C1020MFP_AOG_ENG.pdf
Go to view the paragraph : Using the machine as a scanner
then you will know how to scan.
Jul 22, 2014 | Kyocera Tk-352
HOW THE TO CHECK WASTE TONER BOX
it's a rectangular white plastic boxthat may be filled with waste toner.you can find a picture of it on the Internet. Usually they're replaced with the maintenance kit but if you're just want a dump it out just be sure thst you do not wash it..
Use compressed air to clean it out. after dumping There's usually a sensor behind it make sure that's clean also
Jul 16, 2014 | Kyocera tk-362 - Fs4020dn 20k Toner...
HOW DO I CHANGE MARGINS
Hi Vicki. It would probably benefit you to post this in the correct section-, i.e Printers and not canon camera flashes.
Jan 09, 2014 | Kyocera Tk-352 Black Toner
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera Printer C5030N
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera Tk-352 Logo
291 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
